I need Navi Help
I need Navi Help
Yeser day I got in the car and began to drive. i took a turn and the navi symb did not follow the road I was on. It actuall ran next to the raod bit not on and road. Just stayed off the raod and the more I drove the more off track it got. Not sure what happened of if this is common. Do I need to rest the navi or something. Is there a way to even reset it? Any ideas please. Thanks
Sǝxy Timǝ in my
I know what you mean. When you set a destination and if you off track to a different road the Navi will think that you still on same road until you move farther apart. I think it is normal, it happens to me too.
A-spec steering wheel ftw
just depends where you are. most of the time it auto corrects...but if you live in an area where the roads are really close together it may never auto adjust, but you can always just move the cursor and set it to where you actually are and i think it remembers, not sure,
on a lighter note,...lol i found out that circle around the cursor? isn't just so it's easier to pin point that place better, it's also marked as the degree of error/freedom in approximation LOL;
made me chuckle.
made me chuckle.
Registered but harmless
Received 1,149 Likes
Is there any way to reset the navi when this happens or will it correct it self when you shut down the car and come back later?
Try hitting the "menu," then "map" buttons to see if that forces a reset if your car doesn't automatically reset its position.
08_UA7_Gr33k
02-11-2016 02:17 PM
lanechanger
10-13-2015 10:56 AM
us285126
10-02-2015 02:03 PM
