I just want to make it louder
Old Sep 29, 2004 | 06:56 PM
RPIdad08's Avatar
7th Gear
Hello. I would like some advise as to just making the stock 04 TL with Navi system louder. I am either going slightly deaf (work in a machine shop for 25 years) or just like the tunes louder than most. (probably both)
Thanks in advance for your input.
Dean
Old Sep 29, 2004 | 07:45 PM
oneilc's Avatar
Kenpachi Teichou
Completely off topic, but do you have a kid who is going to RPI (the college in Troy NY)? or does RPI stand for something else?
Old Sep 29, 2004 | 07:58 PM
92NSX's Avatar
Advise or advice???
Old Sep 30, 2004 | 11:45 AM
DWP's Avatar
DWP
He meant "advice." If you're a geezer like me with hearing loss, the problem is mostly in the higher frequencies. Just increasing the volume won't necessarily help, but turning up the treble (and maybe turning down the bass) might help. This particularly applies to speech, but can also apply to music. I don't have a TL (yet) but I assume its audio system has an equalizer of some sort that allows those adjustments. The better solution is a hearing aid, but I'm not quite ready to go there yet.
Oh, and I would strongly suspect that he is the father of a member of the RPI class of '08.
Old Sep 30, 2004 | 12:42 PM
oneilc's Avatar
Kenpachi Teichou
If only he would answer ... don't post and leave!!!
Old Sep 30, 2004 | 02:38 PM
ludachrisvt's Avatar
Wants an M3 in
go to setup and turn the volume up ... a tone will sound every time u turn it up ... it gets REALLY loud so if u cant hear it at max vol then you NEED HELP :P
Old Sep 30, 2004 | 04:14 PM
someone's Avatar
Try PM or email, sometimes people dont have notification enabled for the threads they make.
Old Sep 30, 2004 | 06:45 PM
RPIdad08's Avatar
7th Gear
Yes to advice, yes to RPI Troy 08, & yes, dont want the hearing aid yet.
How about an amp?
I didn't know spelling counted for so many points!
I'll play with the adjustments some more. Although I think I "need more power"
Dean
Old Sep 30, 2004 | 06:54 PM
92NSX's Avatar
Dean
Just wanted to make sure I understood exactly what you were trying to convey.
Old Sep 30, 2004 | 07:24 PM
oneilc's Avatar
Kenpachi Teichou
How about an amp?
Dean
I went to RPI.
Pros:
- Great education
Cons:
- 4:1 guy to girl ratio. If you have a son, he won't get laid for 4 years (unless he likes going hoggin ), if you have a daughter she'll become a stuck up beyeeeoootch because all the guys will take anything.
- SNOW
- TROY
- Expensive!!!
Feb 25, 2020 09:57 AM
cycdaniel
Dec 17, 2019 10:58 AM
johnpancakes014
Apr 8, 2016 06:47 AM
pistacio
Sep 26, 2015 09:45 AM
