How to run speaker wire
Old Jul 4, 2012 | 11:13 AM
Joey tl's Avatar
04' tl 6 spd
i search and found nothing. im trying to run speaker wire from my crossover (door) to tweeter (dash) if possible. tell me what you guys did. picture would be helpfull thanks
Old Jul 4, 2012 | 12:22 PM
pohljm's Avatar
get that crossover out of the door! not the best place for it anyway. then you can easily run wires to your tweeter. and either #1 use the factory wire to the mid, or #2 re pin the molex connector with new wire, or #3 drill out a section of the molex connector and fish wire thru
Or keep it there and then do either #2 or #3 to feed back to the tweet..
Old Jul 4, 2012 | 12:31 PM
pohljm's Avatar
Here you go!
https://acurazine.com/forums/3g-tl-audio-bluetooth-electronics-navigation-94/how-route-speaker-wire-front-door-speakers-w-pics-859849/
Old Jul 4, 2012 | 02:36 PM
I hate cars's Avatar
I don't know if it's the right way but for the tweeters, I stick the wire through the tweeter hole and I find it down in the dash and pull it through. Looks like the doors have already been taken care of. There's a junction box behind the glovebox. Since the doors and tweeters are on the same amp channel, this is the point where the signal splits and goes to the tweeter and the midbass. It's full range up to the tweeter where the factory tweeter has a cap to block the lower frequencies. You can always tap into the stock wiring here but it's just as easy and probably better to run your own wiring.
Feb 25, 2020 09:57 AM
Soul_Deamon
Nov 13, 2018 04:44 PM
JarrettLauderdale
2G CL Dynograph Gallery
Sep 21, 2015 07:51 PM
04tler
Sep 10, 2015 01:13 PM
alan_rich
Sep 7, 2015 11:08 PM
