How to extract pins from connectors?
Old Jan 10, 2009 | 09:04 PM
SQAcuraTL04's Avatar
Ok, so I should be about ready to install my navigation in about a week or so. I been toying with an old connector trying to de-pin it so if something happens during my install I'll have the know how right now so I can fix things when the important stuff happens. Anyway I have tried everything, I have tried forcing the pin out with a pick, pushing through the back with a paper clip and well I must not be doing something right. So if anyone has any pointers on how to do this without spending $50 on a kit, I am all ears. Also if someone could at least explain to me how exactly these pins lock into place that would be helpful as well.
Old Jan 10, 2009 | 10:26 PM
so cal eddie's Avatar
Get a molex pin extractor. Ive got a couple and i think they were like $15 each. The pins push into the connector and then flare out to hold onto the connector.
Old Jan 10, 2009 | 10:29 PM
Also some pins require another tool that looks like 4 small picks at the end. I dont have a good way to explain it but gm sells them at their parts shops. SHould be like 10 bucks.
Old Jan 11, 2009 | 03:44 AM
IBFStyles's Avatar
Get a really tiny flat head screwdriver and push it out from an angle. There's only one groove in the pin it's real simple.
Old Jan 11, 2009 | 07:47 AM
One of these?
http://cableorganizer.com/molex-extraction-tool/
and how does it work? do you push through the back where the male pins go in and does it slide ride out?
Old Jan 12, 2009 | 03:58 PM
iSimple's Avatar
PXAMG GuRu
i use these....
cycdaniel
Dec 17, 2019 10:58 AM
copmagnet82
4G TL Problems & Fixes
Jun 29, 2016 08:09 AM
xsilverhawkx
Sep 28, 2015 06:51 PM
polish_pat
Sep 25, 2015 12:24 PM
ivegotthenav
Sep 11, 2015 07:51 PM
