how can I replace these bulbs??
Old Nov 10, 2008 | 07:30 PM
JumboSushi's Avatar
B A N N E D
Just found out these light bulbs on the up & down button of the climate control , and the heated seat switch bulbs are gone. Anyone can show me how to replace that ??
thanks !!
Old Nov 10, 2008 | 07:41 PM
ikechun's Avatar
04 TL - CAR_PC
You have to remove center console and radio to replace the bulb.
Heated seat indicator light is easy but AC control is not easy cause you have to remove all center console, clock, under dash trim to access.
Search the forum there is instruction somewhere and bulbs are dealer only items.
You could buying at the local dealer 3-5 dollars each.
Heated seat indicator is amber, illumination light is white, ac control also white.
Actually amber with blue rubber cap on it. it so very small.
Removing center console is not fun and care needs(If you break any molding or plastic part will be expensive.)
good luck
Old Nov 10, 2008 | 07:51 PM
JumboSushi's Avatar
B A N N E D
good luck
Thank you for your inputs. I think I will do the heated switch bulbs first if it is easier.
Do you know what I need to remove in order to get into the heated switch bulbs??
Old Nov 10, 2008 | 07:55 PM
RACINGHART03's Avatar
Silver side trim, two screws in console under rubber mat, two screws furthermost ears rear half of the center console. Slide it back a little. the wires that are still connected run to the rear acc. socket but you have plenty of room to work. Remove the foil that covers the bulb sockets on the seat heater switches. I use a flat blade screw driver to remove the bulbs. Reverse the steps to reassemble.
Old Nov 10, 2008 | 08:14 PM
JumboSushi's Avatar
B A N N E D
thanks a lot!!
does those lights bulbs are only Acura dealer item ??
Old Nov 10, 2008 | 09:16 PM
ikechun's Avatar
04 TL - CAR_PC
Originally Posted by JumboSushi
thanks a lot!!
Bulb is so little and no after market bulbs are available.
I guess all japanese car use same type of bulbs.
I have toyota sequoia indicator light bulb using same type of bulb.
But, Better buying at the dealer.
Old Nov 10, 2008 | 09:27 PM
ikechun's Avatar
04 TL - CAR_PC
Here is forum that show how to remove center console.
https://acurazine.com/forums/3g-tl-2004-2008-93/those-who-have-service-manual-i-need-help-3g-garage-f-052-a-557238/
Old Nov 10, 2008 | 09:53 PM
JumboSushi's Avatar
B A N N E D
thank you very much !!!
Old Nov 10, 2008 | 09:56 PM
xen-cuts's Avatar
ROFLCOPTER!
wow, i have the same lights out in my car. I'm planning to deal with this over xmas holidays...
Old Nov 12, 2008 | 06:51 PM
jguerra23's Avatar
Looking for new mods
I got these changed under warranty
Old Nov 13, 2008 | 07:36 AM
LoveMyTL-S's Avatar
In my old TSX I had both seat heater bulbs replaced under warranty at the dealer. Perhaps that's an option.
Old Nov 13, 2008 | 12:20 PM
JumboSushi's Avatar
B A N N E D
Conclusion is Acura use cheap bulbs !!!!!!
oo7spy
Jun 19, 2023 12:48 AM
pplcrew
Jan 30, 2021 08:59 AM
acuraST
Sep 17, 2015 02:31 AM
brjones9
Sep 3, 2015 07:30 PM
pesobreeze
1G RL (1996-2004)
Sep 3, 2015 12:26 PM
