How to add an amp?
Old Jan 15, 2015 | 01:19 AM
ryanhono's Avatar
How to add an amp?
I have a 06 acura tl and i want to keep the navigation but dont know how to instill the amp properly. I have the wiring kit but how do i get the rca's to hook up to the head unit for sound signal? Also if anyone knows of a ipod and rca combo adapter let me know thanks!
Old Jan 15, 2015 | 09:12 PM
cipher9878's Avatar
you need to get an LOC and tap it into the sub if you want to still have oem control of the sub.
Old Jan 16, 2015 | 11:35 AM
ryanhono's Avatar
what is an LOC? if you could could you send me a link of what you are talking about or what you put in your car?
Old Feb 19, 2015 | 04:03 PM
papachingy's Avatar
A loc is line output converter....pick it up, run your stock amp wires to that and rcas from the loc to the amp and presto magico
Old Feb 25, 2015 | 10:48 PM
QuickTL07's Avatar
OP its little more dificult than just hooking up lock. Even though our TL oem radio have nice flat signal, you should be ok, just remember to set your gains properly, and not clip your amp, or you will burn your sub....
I know your next question will be what gains, or whats clipping
Old Mar 3, 2015 | 08:48 AM
maverick06xx's Avatar
I have asked this question and haven't gotten any answers, I want to install a LOC also, but what I wanted to know is when disconnecting the stock sub wires and using the LOC and tapping into those wires, isn't the stock amp still feeding power to those wires, and if so is there any danger from it? should I disconnect the wires at the stock amp and wire the loc to those wires? i'm just not understanding and some help would be great. I know if I use the stock sub wires I will have control of my sub so I wouldn't need a gain knob as some users have told me...Anyway any help and pictures would be great as I have searched all weekend on this and haven't found anything and pictures from the past posted on this subject doesn't work, thanks.
Jul 16, 2017 07:33 AM
soupi
14
Nov 15, 2015 11:15 AM
InFaMouSLink
Oct 30, 2015 09:43 AM
ROSSARONIE
Sep 22, 2015 11:46 AM
