HFL Voice recognition problems
Old Nov 14, 2006 | 10:22 PM
robinmcd's Avatar
Angry HFL Voice recognition problems
I am trying to enter some numbers in my phone book (2006 TL) and am having a hard time. It recognizes about half my numbers and then it sometimes adds a long string of numbers or pauses to what I have said,....in short - just screws up what I say. Anyone else have a problem with the voice recognitiion thing? I'm in the south - maybe this car was manufactured "up north!" hehe
Old Nov 14, 2006 | 11:06 PM
jzacuto's Avatar
Up north, eh? Maybe that's what it's all aboot, then, eh?
I found that if I RESIST the urge to slow down when saying numbers, it actually recognizes them better. Instead of pausing for a second or two in between numbers, try saying them in a steady stream.
Old Nov 14, 2006 | 11:10 PM
71Chally's Avatar
I have similar experience. It seems only about 50% reliable. My solution is to work slowly and only add 3 numbers at a time, verify them and then add the next section. doing it this way, you can back up if it guesses wrong on the block of 3 numbers and not loose the numbers you earlier entered!
My other car is a: 71Chally
Old Nov 15, 2006 | 12:06 AM
Will Y.'s Avatar
Registered but harmless
Originally Posted by jzacuto
...Instead of pausing for a second or two in between numbers, try saying them in a steady stream.
My HFL works well and is at its best when I just rattle off the numbers as if leaving the number on someone's voicemail/answering machine.
Otherwise, if I try to enunciate numbers slowly and clearly, the HFL will enter improper numbers!
Old Nov 21, 2006 | 01:07 PM
Modeler's Avatar
After getting HFL module replaced on my 04 TL, I can rattle off the numbers at pretty much any speed in pretty much any road noise conditions. I still get 95-100% recognition rate.
There must be something wrong with your HFL unit (or with your pronounciation :-) )
Old Nov 22, 2006 | 02:08 PM
71Chally's Avatar
Is there a field upgrade for the HFL
I wonder if the module you had installed is in fact an '04 HFL or if you got a field upgrade? From my discussion with HFL support, it seems that there is an awareness of problems with the systems, but no published upgrade plan. A warranty replacement might include an upgrade though. Service parts are often upgraded to fix problems. Honda issued a whole new Power Door Engineering kit to fix a problem with my Odyssey a few years ago!
71Chally
Mike Pilipenko
Mar 26, 2024 09:21 PM
SidhuSaaB
May 30, 2020 12:40 AM
12vancover
Oct 16, 2015 12:04 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
95oRANGEcRUSH
Sep 25, 2015 12:50 PM
