HFL Problems
Old Mar 13, 2009 | 11:01 AM
waleed's Avatar
HFL Problems
Hello, I had recently replaced my Radio / CD Player. I am running into an issue ... the HFL is not being recognized. It displays the Signal Strength and the Batter on the main display, however when I go to press the HFL buttion on the steering wheel, all it displays is "Main Menu" in the smaller display, and doesn't even say "Say a Command" how can i go about resetting this? What's the work around?
Old Mar 13, 2009 | 01:20 PM
Fulani has a TL's Avatar
Pull the neg. cable for 10 mins, be sure you have all codes ready
Old Mar 13, 2009 | 01:38 PM
waleed's Avatar
would you say this is a problem with the radio? or it's just a matter or resetting it? and also, i see the car is attempting to connect to the phone and when i enter the pass code (0000) on the phone, it says unable to connect and shows as "pair" on the small display ....
Old Mar 14, 2009 | 12:22 AM
waleed's Avatar
didnt work ...
Old Mar 14, 2009 | 05:30 AM
waleed's Avatar
Can someone please help?
Update: when i press the "talk" button on the steering wheel, it goes to main menu *remember: the CD keeps playing* and i see Main Menu on the display, if i say phone book, it will recognize it and display phone book .... what do i doo
Old Mar 14, 2009 | 11:41 AM
pbcmedia's Avatar
HOME SWEET HOME....
if all else fails take it back to the dealer there was a service issue about the hfl, hopefully you're still under warranty because its expensive to replace.
SidhuSaaB
May 30, 2020 12:40 AM
Fool
Mar 10, 2016 08:42 PM
12vancover
Oct 16, 2015 12:04 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
MikeJM310
Sep 24, 2015 07:24 PM
