HFL - Make calls from cell phone?
Old Jul 23, 2005 | 01:26 PM
iTISTIC's Avatar
Is there anyway I can initiate a call from my cell phone and have the HFL system kick in and take over the call? I know I can transfer to the HFL after I make the call according to the book, but with my cell phone as soon as I hit send on the cell phone it disconnects from HFL and makes the call through the cell phone.
My cell phone is a Nokia 6255i.
Sometimes I have to look through my phonebook in my phone for a number, and would rather just press send than have to give HFL the voice command to dial the number.
Old Jul 27, 2005 | 02:47 PM
Bernard1973's Avatar
have same issue,
shit also happens when making a call with cell (HFL on) you get incomming call, both get disconnected,
anybody hava solution
Old Jul 27, 2005 | 03:40 PM
Brewmaster's Avatar
I'm Baaack!
You can toggle back and forth between the handset and the car by using the "Transfer" command.
Once the call connects hit the HFL and say "Transfer" it should bring it over to the handsfree. You'll have to wait until the call actually begins to connect or it'll just drop. I've done it with limited success on mine... usually because I try it too early in the call.
Old Jul 27, 2005 | 04:01 PM
Thorin78's Avatar
Previous Owner
It depends on the phone. With my SE Z600, I can initiate say the command while it's ringing. If it's too early it says Phone In Use. If you do it right and it transfers over, your MID will say In Use.
With my SE Z800, I have to wait until the call actually connects to do the transfer and even then it may say Phone In Use. With the Z800, if I call via the phone it automatically asks me if I want to receive the call on the handset, if I say no, it transfers over to the HFL and well that's no good as the car doesn't pick it up. go figure.
Old Jul 27, 2005 | 04:53 PM
iTISTIC's Avatar
I am able to transfer calls from the HFL to my phone using this method without any trouble. I cannot transfer calls from the phone to the HFL using this method if the call originated on the phone. In other words, if I hit send on my phone my phone immediately disconnects from the HFL, leaving me with no way to transfer to it.
Old Jul 27, 2005 | 05:14 PM
Kubrus's Avatar
i have a blackberry and transfer calls all the time, rather than having to put 100 people in my car's memory. The first attempt (and sometimes second) is always a failure with the transfer command (the first time seems to force the system back to radio), and on the 2nd or 3rd attempt connects the call. Usually, the phone waits to connect the call until it's transferred to the HFL...
Old Jul 28, 2005 | 01:59 PM
bhubb3rd's Avatar
I also have a BB 7290 and would like to know a simple way to initiate a call from my BB address book and have the HFL pick it up. Now, if I look up a name and hit dial, it just dials on the BB and won't connect with the HFL. Transfer is a poor choice, never works until the call is connected and then the person on the line is wondering why no one is there!
Any other ideas???
Thank you.
Old Jul 28, 2005 | 02:24 PM
sharontha's Avatar
I have a Sony Ericsson T637 and i have had hidious time trying to use my voice mail thru the HFL system because of the touch tone prompts, to the point where i had to be out of the car to check my VM. so one day i disconneted the bluetooth link thru the phone(takes a few secs) and dialed. to my suprise after the call was placed the HFL automatically picks up the call after the call is placed and i'm able to use the touch tone promts thru my phone(which i was unable to do before). i also do this now for numbers on my phone book, try this it might work.
IndycarFaster
Sep 11, 2015 02:52 PM
iRaw
ILX Photograph Gallery
Sep 10, 2015 12:29 AM
