HFL Locks Up
Old Mar 28, 2009 | 06:39 PM
leem's Avatar
HFL Locks Up
I recently purchased a 2004 TL with navigation and it has 70,000 miles -- out of warranty. Discovered it has a bad HFL module -- also verified by local Acura dealer. My HFL problem is related to Service Bulletin 05-020.
I am trying to find a replacement for the HFL module but Acura parts list the 2004 module as being discontinued (P/N 39770-SEP-A01ZA). Probably because the unit was replaced by a kit as described in the SB with P/N 04397-SEP-305ZA. Have not been able to find this kit on any online stores but can find the HFL module for a 2005 TL with a slightly different number than the original 2004 TL. The 2005 TL HFL unit P/N is 39770-SEP-A02ZA.
My question is can I use the 2005 TL HFL unit as a replacement for my original defective HFL unit in my 04 TL?
Any help would be appreciated... Thanks
Old Apr 26, 2009 | 10:48 AM
leem's Avatar
Follow up on my previous entry....found and purchased a Bluetooth Module on Ebay for $146.50 (including shipping). Replaced the original in my 2004 Acura TL with this module. Bluetooth now works great -- no problems so far. The unit I installed had a manufacturing date of 9/7/05 so assume it was originally from a 05 or 06 Acura and as stated above it is now working. A lot cheaper than the $900 the dealer wanted to fix problem.
Old May 5, 2009 | 03:53 PM
badteddy's Avatar
are there any pics of said fix?
Old Jul 16, 2009 | 12:03 PM
juicdawg18's Avatar
Where on ebay did you find it? Could you help me out, my HFL is inoperable and took it to the dealer and they are telling me I need a new HFL unit. For them to do it (including labor) it is $750, I would much rather get it for the $150 as you did. I have a 2005 TL w/Nav.
Old Jul 16, 2009 | 01:30 PM
LoveMyTL-S's Avatar
Awesome! Thanks for sharing. I'm sure it will help many people in Acurazine....... That is what this forum is all about.
Old Jul 16, 2009 | 01:34 PM
BradE's Avatar
If you are getting a dealer replacement, most of the cost should be just the part. The book time for the install is only 0.5 hours. It's 4 bolts and a couple wiring harnesses, not anything hard.
I just had mine replaced under warranty because the housing busted at all 4 mounting points, it took them 20 minutes tops to install it.
Old Nov 17, 2009 | 05:05 PM
cwharper's Avatar
8th Gear
Just found out my module is dead and the dealer wants $1,300 plus labor for a new one. Where did you find your's on e-bay? what exactly did you search for?
MrHeeltoe
20
Feb 23, 2023 01:54 PM
soupi
14
Nov 15, 2015 11:15 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
DementiaPhuro
Sep 29, 2015 05:31 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
