HFL Drain
Old Jul 10, 2011 | 05:18 PM
moreace's Avatar
Anthracite Trend Setter
HFL Drain
Hi all,
I have read a number of the posts on this, but have a specific question as I am not sure this is my issue or how to correctly diagnose the issue.
I am on my second Acura battery that died today at 3.5 years old (same as the first, thought that one did not ever completely die).
Although the car is 7 years old, I have only started using bluetooth in the past few weeks when I picked up an iphone.
Would the BT be draining the battery if this was the issue all the time or only once a phone is paired? Is there anyway to test to see if it's the HFL? I don't have any tech to test amps or draw.
The car was cranking extra long, but starting for a day or so, but now is completely dead. Sounds like the Optima Red Top is the best battery to replace it with.
Would Acura still have to replace a faulty HFL out of warranty if they never did so under the original TSB?
Appreciate your thoughts. Thanks!
Old Jul 10, 2011 | 06:11 PM
Will Y.'s Avatar
Registered but harmless
The Acura battery reputedly doesn't last very long, and 3.5 years is not bad.
Switch to a new battery first-- Interstate, Red Top, Kirkland: they're all fine-- and see if you have any issues. If your new battery lasts longer than a year, the HFL is working fine and not locking open.
Acura doesn't have to replace the HFL out of warranty since it was under a TSB and not a recall.
MetalGearTypeS
Aug 29, 2016 08:28 PM
hpfiend
Sep 27, 2015 06:59 AM
phillyguerrilla
Sep 26, 2015 11:27 AM
Rcelestino93
Sep 23, 2015 10:01 PM
STL TL-S
Sep 23, 2015 08:52 PM
