HFL connecting and disconnecting problem
Old Mar 8, 2014 | 11:18 AM
Skirby12's Avatar
Hi guys. I did a search but haven't found the same problem I'm having.
Recently when I start my car the hfl recognizes my phone but only for a couple minutes then the phone icon disappears on the display. The diagnostics show the whole system is working properly. I took the hfl unit out to check for any obvious issue but found nothing. Anyone else have this problem or know what it could be. Not sure if it would be the hfl unit or not. I've seen on here that they can be problematic.
Thank you
Old Mar 8, 2014 | 07:41 PM
77donovan77's Avatar
....just dancing in
You may want to try looking into your phone bluetooth connection. Sometimes the connection is loss. On your phone, go to setting, bluetooth and then see if the
HandsFreeLink TM is highlighted. Sometimes the two would lose its pairing connection.
I would have this issue when I forget to turn off my bluetooth headset.
Good luck
Old Mar 22, 2014 | 07:07 AM
Skirby12's Avatar
I tried the baking method and it has improved the problem but still cuts in and out. Must be time for a new module
Old Mar 22, 2014 | 07:13 AM
quake97's Avatar
Sounds like it, yeah. Does it do it with any other phones? Perhaps a family member or significant other.
Joe
Old Mar 23, 2014 | 07:50 AM
Skirby12's Avatar
It does it with other phones too. I tried 3 different phones with the same result
mada51589
Jan 9, 2025 04:40 PM
cycdaniel
Dec 17, 2019 10:58 AM
visiter555
Apr 9, 2016 12:56 PM
BigJilm
Sep 21, 2015 08:32 PM
cali boy 91
Sep 19, 2015 01:57 PM
