HFL being retarded
HFL being retarded
So, I'm driving home from work last night and make a phone call with the HFL froze up. Now it's stuck saying in use and I can't even use the radio.
I was wondering if anyone has experienced a similar problem or has any ideas on how to reset the HFL? My only idea is to pull the negative battery cable for a bit and see if it resets it.
VS#03
Yeah.....I have the same problem too, my bluetooth stays on permanently. I tried to turn it of by my phone and it has a note saying bluetooth is busy, which it wouldn't let me turn it off.
Originally Posted by dan.....k
Pull the negative cable. I had something similar happen. It wouldn't stop ringing. This should fix your problem. If you have an 04, I would recommend getiing the HFL replaced. I just did this and can tell you the new one is much better.
So how do you get it about getting the module replaced? My HFL is frozen now and I want to get it replaced since this is the second time it froze.
I just don;t want the dealer reconnecting the battery/or removing the fuse and saying the HFL is fixed.
I was just down in NC visiting family and my sister had the same issue with her '05 TL. I had to hit the hang up a few times to disconnect, then turned phone off and car off. The car on and phone on in that order, and it works OK now.
phillyguerrilla
09-26-2015 11:27 AM
rmittal
1/2G MDX (2001-2013)
09-19-2015 08:41 PM
