Help with Ulead DVD MF 4
My brother has the Ulead DVD Movie Factory 4 on his lap top but i dont see the burn.now software on it. Can anyone point me the right direction on how to burn a dvd audio cuz i dont see the burn.now program on there. I went to the ulead webstite to look for the patch but dont see it. can anyone help.
thanks
has anyone try this program out yet? does it record in 5.1 audio?
thanks
The DVD-A Script Guy
Come on people.... search !
There are LOTS of posts about making DVD-A out there so you will be bound to catch some sh|t from others.
Easy (what I use) = Cirlinca DVD Audio Solo. 34.95 with a generous free trial. www.cirlinca.com
Free = My scripts. https://acurazine.com/forums/showthread.php?t=118963
Either of the above will require you convert your mp3s to wav first
Expensive POS (sorry) = If you absolutely do not want to convert your mp3s to wav then there is a Ulead tool that has had some really bad experiences plus it is a $99. https://acurazine.com/forums/car-talk-5/my-roommates-vw-gti-121358/
__________________
- Adobeman
'05 6MT ABP/Camel w/o Nav
__________________
- Adobeman
Expensive POS (sorry) = If you absolutely do not want to convert your mp3s to wav then there is a Ulead tool that has had some really bad experiences plus it is a $99. https://acurazine.com/forums/showthread.php?t=121358
__________________
- Adobeman
__________________
- Adobeman
thanks
Originally Posted by bored7one4
The reason im asking is becuase i dont want to convert MP3 to wav when making the dvd-a. in your thread, you said to use Ulead MovieFactory to make dvd-a audio but i dont see anything in the Ulead MovieFactory that would let you burn dvd-a. I've read that Ulead does make a program called Burn.Now that does let you burn it but you need the full version of it cause i dont think you can download the patch with the trial version. So i guess all i want to know is that the burn.now is the program i want right? not the ulead movie factory?
thanks
thanks
Now, be sure to buy MovieFactory Creator Deluxe version 4. The component that is used for DVD-A creator is Burn Now 2.0. You can NOT buy this component by itself, however it is included in this poackage which lists for UNDER 99 DOLLARS and gives you a compolete authoring package for CDs and DVDs as well as the DVD-A Creation.
Just a suggestion. A free tool like CDEx will convert just about anything to wav files for your. It will also do them in a batch mode. Then a tool like DVD Audio Solo will make the DVD-As for you. This is a process many others have found successful. It will cost you $0.00 for the first 7 disks. After that you will need to get a license for solo at about 1/3 the price of the Ulead tool. If, however, you want the other features that MovieFactory Creator Deluxe offers then go for that since Solo only does DVD-As.
well i give the dvd solo program a shot but when i convert about 50 songs and try to put it on a DVD, i get an error in Solo Dvd saying (Not enough disk space for temporary files : 7760556K/7075836K on drive)
why is that?
right now i just pick out 12 random songs and it looks like it working but how come only 12 on a disc? Isn't it suppose to fit like 99? Is it my DVD -R ?
i just notice each songs in wave format is around 110mb to 140mb depending on the song is that normal?
thanks
and sorry for all the question.
why is that?
thanks
why is that?
why is that?
why is that?
thanks
why is that?
thanks
1) Do you have any "up-sampling" selected on ? As in from 44.1Khz to 96khz ? If so I don't recommend it. It will cause Solo to build temporary files first and then it will build your HDD. This means you will need a minimum of 2x of what you might think. Each temporary file will be bigger and so will the DVD-A structure prior to burn. Many times this is the culprit in disk space issues.
2) Songs can be any length but a typical 4 to 5 minute 2-channel song at 44.1K/16bit is usually in the 40 to 50 Mb range so I think you may have songs at a higher sample rate and/or bit depth. (or they are > 2 channel)
I suspect #1. 50 "typical" stereo songs at 44.1K/16bit will average in the 3 - 3.5 G area. If you have any re-sampling/upsampling going on then that could boost you well over that into the 7G range you are being warned about.
lol c'mon people
please respect those people giving us answers here.
On the other hand, regulars please consider first timers and non-regulers get directed to "search" button properly.
As adbeman said
1. DVD audio solo (best value for both 2ch,5ch)
2. adobeman's scrip (free for 2ch)
3. ulead ($99, only 2ch)
BoricuaTL
04-08-2016 01:08 PM
