HELP with Sub Install
Old Oct 21, 2004 | 08:50 PM
ayethetiense's Avatar
.:KCCO:.
i cant figure it out. it doesnt work.
i have power coming through.
where can i easily attach the rem wire?
the ground should be good.
with those three things, i should have power. but i don't. i tried to hook the rem wire to the bottom left panel in the drivers footwell to the white with red wire. that should be the accessory wire no? i can't figure it out.... nothing at all. should be so simple
anyone have any ideas? whats the color of radio wire from the drivers footwell?
Old Oct 22, 2004 | 12:41 AM
SSM6MTNAVI's Avatar
Weather Watcher
Try hooking the remote wire to an accessory fuse in the fuse box by the drivers footwell. Thats how I hooked up mine. I think mine is hooked up to the heated seats so the amp only comes on when the key is the Acc II position. Seems to work well esp when I am cleaning my baby and don't want the amp to drain the battery. See how that works out for you. Good luck!
Old Oct 29, 2004 | 09:19 AM
cable's Avatar
i would follow the post right above mine...look for the fuse box and attach it to a unit that you want the amp to turn on with...that's how i always install my remote if you choose not to use the actual radio remote wire...
cycdaniel
Dec 17, 2019 10:58 AM
giovane
2G RDX DIY & FAQ
Jul 8, 2016 10:46 PM
pistacio
Sep 26, 2015 09:45 AM
TxRzrBk
Sep 17, 2015 01:07 PM
