Help removing the front Grill
Old Sep 30, 2004 | 03:22 PM
rescueswimmer's Avatar
Hey Just a quick? I am installing my zr3 laser shifter and I am think Im puting it right under the hood bye the grill inserts. This is per the people at escort for optimal performance. I dont want to saw the plastic to make it fit so I was going to remove it and do a test fit befor I do any type of cutting. Does anybody know how to remove that piece or do I have to take the bumper off to take off the mesh. Thanks
Im using spots 1 and 2
Old Sep 30, 2004 | 04:22 PM
cM3go's Avatar
remove the tabs at the top when you open the hood, that should get you behind the grill and access to the tabs (i believe) to pop the grill out of place
Old Sep 30, 2004 | 06:00 PM
I removed those tabs but when you get there that thing doesnt budge. Not sure what else I need to remove thanks
Old Sep 30, 2004 | 08:17 PM
SLVR04TL6PD's Avatar
VegasTL might know,
he had to remove his bumper to install his cleared out headlights.
-Chad
Old Oct 1, 2004 | 10:23 AM
anybody else have any connections to find this out. I allready removed the snap clips holding the top part in but cant see how the grill would come off. Thanks in advance
Old Oct 1, 2004 | 11:11 AM
bklynpanman's Avatar
321 whp SAE
use spots 3 and 4 i put my shifters there and they work great
Old Oct 1, 2004 | 11:44 AM
Ron A's Avatar
Administrator
Some people have reported that they can get between the grille and the radiator from the bottom, and there is enough room to put your radar detector stuff in there and secure it to the brackets with tie straps.
If you want to remove the grill, you have to remove the front bumper, and the grill comes off with it.
I am going to move this to BT/Navi where more radar people will see it. If you don't get any good info by tonight, I will try and get a picture of the page from the service manual into this thread.
Old Oct 1, 2004 | 12:15 PM
mporter410's Avatar
Sorry for the ignorance, but exactly is a lazer shifter?
Old Oct 1, 2004 | 01:33 PM
Pretty much its a nice way of saying JAMMER. They way it works is if you are lazed and have just a detecter. Its going to go beeeeeeeeeeep. but guess what your toast dont even bother slowing down just pull over. The way the shifter works is that if you get lazed it actively blinds the gun and sends it back all 000's for the speed. With laser guns the cop is supposed to do it a couple of times cause sometimes the gun doesnt get a good reading so when he goes to shoot you again and you have slowed down to the right speed. You can tap the mute button 2x and it disables it and allows him to get your speed. Although you could just leave it on and take the chance that the cop will want to talk to you.
Old Oct 1, 2004 | 01:34 PM
did you mount it behind the grill or did you modify the grill so they would stick out the better.
Feb 25, 2020 09:57 AM
TLDude876
Dec 28, 2016 03:18 PM
DwDrummer
5G TLX Problems & Fixes
Sep 14, 2015 08:20 PM
08 NBP TL
Sep 8, 2015 08:49 PM
truonghthe
Sep 7, 2015 11:17 PM
