Help Pair Galaxy S3!!
Old Feb 5, 2014 | 10:11 PM
Jasiel_elek's Avatar
7th Gear
I've had trouble pairing my Samsung Galaxy S3 with my 05 TL. Anyone have any advice?
Old Feb 5, 2014 | 10:20 PM
aboysua6's Avatar
I'm having the same issue...
Old Feb 5, 2014 | 10:32 PM
Vlad_Type_S's Avatar
Registered Bike Offender
I have the 08, but my S3 pairs fine. Which part of the procedure are you having a problem with? The owner's manual describes exactly what you need to do. Make sure you're putting your phone in discoverable mode. Do this in Settings>Bluetooth and then check the first box (in my case, it says "Vlad's Phone", but this will be the name of your device)
Old Feb 5, 2014 | 10:36 PM
MandoTL's Avatar
I have a Note 3 and it connects to my 05 TL no problem. And my mom's GS3 is linked to my car too so when she uses it.
If you have your manual it can explain also the proper procedure since "phone setup" option usually doesn't appear on the voice commands to get things to work.
But please explain what part in the process is not working.
Old Feb 5, 2014 | 10:42 PM
7th Gear
Yeah, "phone setup" definitely does not work for me. I simply get a reply of "please repeat" but no further options to pair phone.
Old Feb 5, 2014 | 10:47 PM
7th Gear
Yeah I'm having difficulty getting further options. I say "phone setup" and get a reply of "please repeat" or "what you say again" I don't get passed that yet.
Old Feb 6, 2014 | 12:05 AM
Do you have an accent?
Just kidding. Your HFL might be toast or maybe the mic is damaged. Does your car have NAV?
Old Feb 6, 2014 | 12:51 AM
nttstt444's Avatar
^Yeah, im still rocking the S3 and it works fine. The phone may not be the issue?
Old Feb 6, 2014 | 06:45 AM
Adobeman's Avatar
The DVD-A Script Guy
Is your 05 Nav or non-Nav?
Also it would be helpful to know what carrier your S3 is on and what versions of Android and firmware you have. System Settings -> About Phone will show you that. Model Number and Android Version would be good to start since "S3" alone isn't enough to be sure someone else who says theirs works is really in the same situation.
But, since you can't even really get the car to get past your first voice request it could be the car (mic, etc.) as others suggest.
Old Feb 6, 2014 | 09:40 AM
7th Gear
Haha I'm not sure that Californians have an accent that can't be read. Yeah it has NAV.
Old Feb 6, 2014 | 09:43 AM
7th Gear
Yes it's NAV, it's on AT&T. Model number: Samsung-SGH-I747 Android Version: 4.1.2
Old Feb 6, 2014 | 11:16 AM
See if the navigation unit takes voice commands. Try something like "find nearest gas station" or "temperature 72". Not sure how much these commands changed from 06-07 Navs, but it would tells us if the problem is with the MIC or the HFL, because it seems to definitely not be with the phone if the HFL keeps asking you to repeat commands and can't find a discoverable device.
Try with a different phone too, to see if you can duplicate the problem.
Old Feb 6, 2014 | 03:04 PM
350's Avatar
350
My first ricer
My S3 works fine, don't remember how to set it up but I followed the owners manual.
Old Feb 6, 2014 | 05:42 PM
BlackAspec06's Avatar
i have an 06 with nav and i was able to connect my S3 to the HFL. My issue is when i receive a phone call the HFL will automatically pick up but wont connect on my phone. Same thing when i make a phone call i can use the HFL to make calls but wont connect the phone any advice is helpful.
Old Feb 11, 2014 | 01:15 PM
gt1's Avatar
gt1
` . ' . SUV haterrr
My S3 worked without any issues. Recently it died and I had to replace the motherboard, making it essentially a new phone. Couldn't pair it- tried many times and gave up. My wife's S3 paired and has been working fine. Mystery...
ExcelerateRep
Oct 14, 2015 08:20 AM
RadiantCycles
ZDX
Sep 26, 2015 09:18 PM
ivan06106
Sep 26, 2015 04:38 PM
rboller
Sep 23, 2015 02:49 PM
pplcrew
Sep 15, 2015 05:22 PM
