Help needed on removing head unit
Hello everyone,
I'm trying to install a 07 audio head unit onto my 05 tl w/ navi. I've saw some post a while back that shows how to remove my original head unit with minimal parts to remove. I can not find it now using the search. Can anyone out there please help me. I got the entire screen and the head unit from 07 tl (I think it's out of another type-S). I just need the instruction to un-mount my original head unit. HELP!!!!!
Gratefully.......
Gratefully.......
take the two silver strips out, then take that rear armrest asembly out. Then take out the shfter area compartments. Then take a flat blade screwdrive and pry up on the edge of the clock display. then you will see all 4 scres to the raido, unscrew and wiggle out.
Originally Posted by csmeance
take the two silver strips out, then take that rear armrest asembly out. Then take out the shfter area compartments. Then take a flat blade screwdrive and pry up on the edge of the vent above the Navi Screen. then you will see all 4 scres to the raido, unscrew and wiggle out.
Let us know how it goes and if you are able to play MP3's with no problems etc...
Originally Posted by psheu
I sure will. after I saw the steps I have to go through, I'm gonna take it into the my dealership and have them do it (Don't want to break any trims, and I think the glove box gotta come off too). My service advisor is pretty cool and willing to help me out on anything I bring to him (had my Acura Brembo Brake installed by him. works like a charm). He said that He'll charge ~$100 for the installation. If all goes as planned, I should have it done by the end of the week. And thanx again for all the help. I will keep everyone posted.
give me until tomorrow 4 PM and i will make a comprehensive DIY for you. Thi way you won't have to spend ur money.
Well, here are the pics.
04-06 Aud.
04-06 Disp.
07 Aud.
07 Disp.
04 - 06 Audio Connec. schem.
04-06 Display Connec. schem.
07 Audio Connec. schem.
07 Display Connec. schem.
04-06 Aud.
04-06 Disp.
07 Aud.
07 Disp.
On display, the only differences are Connector A (14 pin) from 05 and Connector E from 07 (22 pin)
On Audio, the only differences are Connector C from 05 and Connector C from 07. The pin location are different 05 have a 26 pin and 07 have 40 pin. I have included all the schem. of the pins. also, the FM/AM antenna connectors are different between these 2 models.
I still have the plug from the cut wires from the 07 head unit. Anyone can help on fabricating the socket/wire adaptors will be gratefully appriciated.
There is at least some instructions in the The 3G Garage
You have to remove the trim and center console to get to the head unit. I have some instructions for the center console removal here: DIY: Backup Camera with Dom's TVandNav2Go PNP Install
Console instructions:
https://acurazine.com/forums/showthread.php?t=90964
But its pretty straightforward. Just follow csmeance instructions. You can use a butter knife wrapped in a thin rag to help pop out the silver trim with out scratching it. Start the trim at the console area and work your way up. I had the hardest time with the top part of the trim, but the rest was easy.
Try the local junkyards and snip off the harness. You could try the dealer, but they probably charge a lot or sell the whole harness only.
the audio harness you can get from a junkyard, and if the pins are the same size, pull them out of the stock connector, and put them in the new one, and the antenna (converter cable) can be bought from honda
Originally Posted by rbf351
just look over the wiring, for the display connector E is the same, they just changed the harness color, and pins 18 and 19 need to be swapped
Great info on the Antenna and display connector plug. if all else fail, I can still keep my original navi screen. the audio plug is the one that get's a little complicated (from 26 pins to 40 pins). I was hoping i can get my hands on a socket where i can mount the cut wires into and plug it into connector in our model year car (sort of like a professional made adaptor).
the part number for the antenna adapter is 08B01-SNA-100
that would be it. you'll have to order it from honda and not acura
As for the audio plug, It'll take more work, I think in 07 there are few more extra wires than 04-06. But, it's not that difficult if you look at the pin schematics I got from the dealer, just tedious wire matching.
Anyway, do you know where I can get sockets for head units in our car? If I can find them, I'm sure I can make a snap-and-go, plug-and-play, adapter to bridge our head units. Again, Thanks
Here is the picture of the 2 different plugs I got that goes into the 07 head unit.
The left one is the plug for the display and the right one is the plug for the head unit:
I wonder if any place sell sockets for the loose end that our original plug can plug into.
*edit*
i see why you are looking for them, but from what i know they are very expensive and hard to get. best bet it to find another radio/navi unit, and rip it off the back
no need for that, take a small flathead screw driver, and pop the pins out of the stock connector, and put them in to the new connector, thats only if the pins are the same size
*edit*
*edit*
But I doubt I can rip them off another radio/navi unit, since the whole unit is worth more than just 2 plastic sockets. Worst case senario, pop all the wires out of my original connector and pop the wires into the new connector (which I don't really want. Cuz, if I decided to switch back to the old system, it's gonna be..... more work).
Originally Posted by PeterUbers
those silver/brushed aluminum trim pieces are $100 EACH! carefull with prying those out .. they are sticky sometimes towards the top
I got some update. The top electronic guy at Rick Case Acura is gonna look into the schematic to see if refitting and re-pin the adapter can work on our car this coming weekend (free of charge). My service advisor told me to call him back after this weekend.
if everything goes well (I hope), I'll take the car in and have them slap everything on. I'm gonna have to get an oil change and some service done anyway plus they'll give ma a loaner for the time they are gonna work on my car. The service department at Rick Case Acura is awesome. Thanx again rbf351 for the info on antenna. It's the input antenna wire for Honda Civic head unit. too bad it's in reverse order. that's the only thing that guy won't do is to cut the wire on the antenna and re-connect them. He told me that he did one on MDX and the FM/AM reception have lot of static. Do you know if there is an reverse adapter like 08B01-SNA-100 . because the input end of that adapter is the same as our car. we need to get the female socket for that end. again thanx
mada51589
Jan 9, 2025 04:40 PM
Soul_Deamon
Nov 13, 2018 04:44 PM
Skirmich
Sep 15, 2015 06:41 PM
