Help with Homelink
Need more information.
Does your garage door opener have a "learn" button?
RAR
most new garages are likely going to be rolling codes. press the learning button somewhere on the garage motor and then keep pressing the homelink button until it syncs. Make sure you clear homelink memory if this is your first time.
I'm Craig
Press and hold the two outer on the homelink for 20 seconds so it clears it's memory. Press and hold the desired homelink button along with your garage door opener button at the same time until the LED starts flashing rapidly- should be about 3-5 seconds. Get on a ladder and press the red learn button on your garage door motor. Run your ass back down to your car and press and hold the homelink button you just stored the garage door opener code to. The LED light should put on a light show indicating its all set. Press the button to test.
Good old search button worked!
What about programming HomeLink to my community security gate?
I have a little gate remote to open the gate to my community and cant seem to program HL to it. I have cleared the memory as mentioned above before I tried but no luck. It just keeps blinking fast which according to the manual, means it uses a rolling code and it suggests to press the learning button. I have looked and cant seem to find that learning button. Is there a different method I could try to get it to work?
I'm Craig
You can't find the learn button on the actual gate itself? There's a chance it wouldn't have a learn button out in the open- for security reasons. If it is a rolling code, the only way to program it involves using the learn feature of the gate/garage.
Thanks.
I have an 05 and 06 TL. Mine took a couple of times to get the Homelink button programmed to my 05 but for some reason I can't get it to program to my wife's 08 TL. I guess when she gets back into town I'll try what cjTL suggested.
-------Tim-------
Hey, cjTL I tried what you said but it was a rolling code. So, I had to press the homelink button I wanted programmed for about 5 seconds then jump up on a ladder press the learn button on the garage opener then run to my car and press the homelink and garage door remote buttons at the same time and after about 2 tries the homelink button flashed fast then solid. Thanks for your help again cjTL.
Dominic@n TL
ive been tryin to do this and its been giving me problems ever since i bought the car and i did my brothers accords homelink and it only took me 5 mins to do his and i still not able to do mines
Keep Right Except to Pass
Even if you program the Homelink properly, sometimes other things can interfere with it. Mine doesn't work much beyond the end of my driveway because we live fairly close to some Defense Department facilities that are known to interfere with garage door openers—shortly after 9-11 quite a few people in the area found that their openers no longer worked and it was found to have something to do with DOD communications frequencies.
About the community gate, you should contact your association and ask them if they'd go open the gate control and press the "learning" button for you. This is a guess but if you don't do that, and it's a rolling code, it will be the same as if you tried doing it for a rolling code garage door when you don't press the button. Lucky for me my community uses a good old 10 pin clicker and they actually don't even change the code from the way it comes from the manufacturer.
Chonny
06-07-2007 03:45 PM
AcuraTLSFan
2G CL Frequently Asked Questions
01-19-2004 10:19 AM
