HELP!! Dash/Back-up lights gone
Old Jan 28, 2007 | 10:36 AM
docthomas's Avatar
No reverse lights. So I went to replace the fuse for back-up on the fuse panel, it was OK, but when I went to replace it the needles and markers around the dash lit up briefly (the numbers did not nor did the ill8uminate with the lights on or the car in drive. Checked under the hood. Nothing I could tell. Is there A Fuse that controls both of these or is it more than one? I have no reverse lights.
Shawn
Old Jan 28, 2007 | 11:05 AM
docthomas's Avatar
Also there is no trip computer or no HFL display at all. This is all black. Everything works, but nothing is illuminated?
Old Jan 28, 2007 | 12:01 PM
csmeance's Avatar
on the left side of the dash, set the brigtness to max a it might have be pushed to low by accident. For the reverse lights, did you make sure you weren't in netural?
Old Jan 28, 2007 | 12:06 PM
docthomas's Avatar
Checked that. I get Driver 1 detected then everything dims and nothign works. The reverse lights don't work at all.
Old Jan 28, 2007 | 12:32 PM
docthomas's Avatar
Exclamation More info...
I started an install for the avelectronic switcher I wanted to do the backup cam . I got the box from AVelectronics.
As stated I have lost reverse lights AND the dash lights. The needle and the blue around the dash light up but the HFL/Trip computer screen lights ONLY to say Driver 1 Detected and then goes black and the Numbers won't light. I have not tapped into anything .I simply ran a wire from the BOX to the Reverse light PLUG and put it in reverse to see if the camera would come on before I wired everything. Nothing happened. SO I took it all apart and noticed that my reverse lights and dash were out. I checked all the fuses. with a fuse tester light and they all seem OK, I replaced any fude inside and under the hood that seemingly had anything to do with the lights but still nothing?
Any clues?
Shawn
Old Jan 28, 2007 | 03:21 PM
docthomas's Avatar
Smile Found It
7.5 FUSE THAT SAID "METER"
whew!!!
CHECKED OUT WITH THE TEST LIGHT, BUT IT WAS BLOWN!!
mada51589
Jan 9, 2025 04:40 PM
Dec 7, 2020 05:39 PM
sockr1
Oct 1, 2015 01:31 AM
wusty23jd
Sep 24, 2015 11:41 AM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
