Help with aux "whirring" sound
I just installed Dom's unit and in dash dvd with audio going to aux. When I'm in any other mode but aux, the system sounds normal. When I pop in a dvd and switch to aux, i can hear the revving of my engine coming through the speakers. What did I do wrong, and how can I fix it? I have an 08 Tl-s
Ended up grounding the Dom unit to the same point as the system. Works fine now.
I did some reading on those ground loop isolators, and they really are a last ditch effort. From what I researched, you should almost always be able to get rid of the sound via proper connections/wiring. All those things do is elimate high range frequencies, so you are losing audio, not fixing the problem.
4drviper
09-23-2015 09:00 PM
