Help! Aftermarket Sub and Amp Installation!
8 Foot Asian
![Talking](https://acurazine.com/forums/images/icons/icon10.gif)
I need technical advice on finishing up my amp and sub installation. The picture below is my crossover that I will be using and I have cut and pasted the specs taken from the MTX website to reduce directing questions back at me.
1. I have disconnected the (+/_) wire that connected directly to the back of the factory sub in the trunk.
2. Taken from other postings on the website and research I have come to find that I need this L.O.C. (Line Output Converter) thing-a-majig to high power stock sub speaker wire down to a low signal that I can plug into my PPI AMP
3. I have purchased a new 12" JL W3 sub 4 ohm dual voice coil and plan to run my old PPI art series 4ohm amp to power this baby.
Can I simply run the stock sub (+/-) wire to the location labled "High Z" on the crossover below or will I have to buy this L.O.C. thingy?
![](http://i89.photobucket.com/albums/k229/cdkruaya/DSC03011.jpg)
Everything is ready to be installed all I need is do I have everything that I need.
8 Foot Asian
Originally Posted by Kirk3272
Correct and you will need to make a couple jumpers to go from right +/- to left +/- or vice versa.
Kirk
Kirk
Originally Posted by cdkruaya
Sorry man but I have no idea what you just said. Are you saying that "correct" I need a L.O.C, or are you saying correct that I can simply plug in my factory sub wires into the High "Z" inputs on my crossover?
K
No LOC needed. Just plug the OEM sub wires into the left or right +/- and then jump to the other side so both sides will have an input.
K
K
![](http://img480.imageshack.us/img480/1417/dsc03011ml8.jpg)
8 Foot Asian
The amplifier cable that I installed is around 12 years old and pretty corroded. I have ran this under the seats and carpet and now I am ready to off myself since its not putting enough juice to the amp. Is it possible to be old and corroded enough to not get enough amps back to the trunk???
Disturbin' The Peace!
If the cable is that bad, I would reccommend a new one. Especially if its coroded. If you want the best from your system, then you need good parts. GL!
05 TL
35k car... You can buy 50-100 wiring kit.
How old is the amp.. PPI Art... isnt that 2000 era.. Perhaps the amp is bad? Also depending on your wiring... The 4 ohm is either 2 ohm or 8 ohm. Back in the day, there wasnt alot of 2 ohm stable amps. But PPI were some of the best.
I am confused, Isnt the OP wondering if he can connect his sub speaker leads to his crossover ? that seems like its not a problem, but why are all the graphics showing connections to the low level inputs and not the high level input? these are speaker level signals, am I missing something?
Originally Posted by Desert_TL
You're confusing "level" and "impedance". High level connections (post-amplifier to speaker) have low impedance and low level connections (pre-amplifier RCA, etc.) have high impedance. "Z" means impedance. So "LOW Z INPUT" means post-amplifier high level inputs.
to access the wires from the stock sub, can you just unplug them from the trunk after removing the covering in the trunk, or do you have to go through the hassle of removing the entire back seat and then rear deck?
05 TL
Ive seen older threads brought back from the dead....
You can take off the inside of the trunk... But your not going to accomplish alot... If you want the sub out you need to take the rear seat out.
Look at this thread: https://acurazine.com/forums/showthread.php?t=170977
Remote turn on for Amp?
Guys,
A few other posters asked the same question in this thread but which fuse are you guys tapping into for the Remote Power? I have tried numerous fuses but they all seem to remain powered even when the car is off and the amp is staying on even with the car off. Any ideas? I do also have a stiffening capacitor. Could the power to the amp be coming from there when the car is off and the key is out?
Thanks in advance guys, I have everything hooked up and have great Bass I am just concerned about the amp staying on...
Thanks again,
-Paul
Thanks again,
-Paul
most people have hooked up to either the 32 or 33 fuse, i am not sure witch one but am leaning more to 32. and if you have a capacitor it is most likely storing power and then dispensing that to the amp rather than the cars power being ran through the wires. If you dont have your remote wire hooked up to fuse 32 or 33 try those and see if you still have the same issue.
AndrewS
19
03-14-2024 06:59 PM
Pegon95
09-15-2015 01:54 PM
trinikidcl
09-04-2015 12:56 AM
