Brand new sound system
Old Nov 30, 2007 | 01:14 PM
tlperson's Avatar
What parts of the trunk would I want to Dynamat in order to minamize rattles. Also I was wondering what guage wire you guys think I should use. I am running a 700w rms alpine amp and then another 300w rms alpine amp. I am using a distibution block. I was thinking of running a 4 gauge wire from the battery to the distribution block then running another 4 gauge wire to the mono block amp and finaly an 8 gauge wire to the 4 channel amp from the distribution block. Would this work?
Old Nov 30, 2007 | 07:03 PM
BukvaMan's Avatar
since u are going trough all that trouble running the wire for a little extra cost i would run at least 2 gauge or even bigger....the purpose, well u never know when u r going to find urself wanting to upgrade to bigger amps another reason is less resistance so a little more juice. As far as dynamat i would recommend both front doors, rear deck, trunk lid and most of the trunk inside. The better u isolate it from rattles the more sound u get from ur subwoofers otherwise is just going to be bunch of noises canceling the sound from ur subwoofers.....and u dont have to use dynamat there is cheaper versions that do the same job no noticable difference. Do it the right way from the beginning or u will be going back and fixing everything and that much more costly and time consuming
best of luck
Old Dec 3, 2007 | 09:19 AM
tlperson's Avatar
Thanks a bunch I will be sure to do all that. Also should I cut into the wiring harness before the stock amp or after the stock amp? I heard about the guys trying to run 3sixty's in there cars and they had to cut into the wires afrter the stock amp. I think this was because the stock headunit doesn't supply enough power. Not sure though.
Old Dec 3, 2007 | 09:24 AM
tlperson's Avatar
Also what is the name of some of these cheaper dynamating materials?
-Thanks abunch guys!
Old Dec 3, 2007 | 09:52 AM
rodneyc77's Avatar
Retired!!! ON TOP!!!
Always.... AFTER the Stock AMPLIFIER...
try the stuff from Elemental Designs.... http://www.edesignaudio.com/edv2/index.php?cPath=24
Old Dec 3, 2007 | 10:09 AM
berzerker's Avatar
Unshunned
http://www.partsexpress.com has some - I've never tried it though.
go to car audio on the left menu
lower right column on the car audio page has sound deaden/dampen products
Old Dec 3, 2007 | 07:35 PM
BukvaMan's Avatar
what i got off ebay was B-quiet ultimate its not to expensive at all and its pretty much the same thing. worked really good for me
http://cgi.ebay.com/Ultimate-B-Quiet...QQcmdZViewItem
Old Dec 21, 2007 | 12:58 AM
stavebomb's Avatar
does it really work? i need to buy some of that!
Old Dec 21, 2007 | 05:19 AM
phu's Avatar
phu
b quiet is the cheapest way to go
Old Dec 21, 2007 | 10:17 AM
jdoggg12's Avatar
RAAMmat is the best performance/dollar mat i've used. I've used b-quiet, Dynamat, spray foam, etc. and raammat performs just as good (if not better) but for a lower price.
http://www.raamaudio.com/cgi-bin/index.cgi?p=pr
I have over 100 ft^2 in my integra and my 1200 watt subs are no louder than stock on the outside when the windows are up. I love that stuff.
Old Dec 21, 2007 | 10:35 AM
topckret's Avatar
-=2005 TL=-
Check out Fat Mat as well.
http://www.fatmat.com/
Old Dec 23, 2007 | 04:39 AM
stavebomb's Avatar
Does it perform as good as is price though? will it eliminate rattles and vibrations?
Old Dec 23, 2007 | 09:54 AM
edsfedup's Avatar
the stuff is all the same. i used edead from elemental designs and covered the rear deck, trunk lid, under the rear seats and all 4 doors. it comes in 3 thicknesses i believe: 45 mils, 60 and 120. i used the 60. dont forget u can stack it too.
the TL is very well isolated as is, but i did see an improvement as far as reducing road noise. almost all of the tire noise i hear now comes from the firewall and fr wheel wells, which are very tough get to.
the sound from the (all stock) speakers has changed. it tightened up the bass a lot which lets you hear the midrange now. most of the bass "boom" comes from resonating panels in the door and rear deck. yes this adds some loudness, but it just ends up hurting the sound overall. so if u like boomy bass, dont dynamat.
as far as eliminating rattles, not sure that this is the correct route. find out whats rattling (with a sound test cd) and fix those problem spots. its usually plastics rubbing together and asphalt-based sound deadening materials wont really fix that....maybe....depends
oh and another thing. it makes your system sound quieter from the outside (with windows up of course). so for all you gas station bangers you might not want to do this.
mada51589
Jan 9, 2025 04:40 PM
rockyboy
Aug 4, 2024 10:35 AM
Feb 25, 2020 09:57 AM
jpadilla
3G RLX (2013+)
Nov 18, 2017 07:13 PM
TLDude876
Dec 28, 2016 03:18 PM
