Have You Installed A Remote Radar Detector?
Old Jan 28, 2006 | 11:43 AM
jlkdoh's Avatar
Question Have You Installed A Remote Radar Detector?
I am considering having a remote radar detector installed in my TL. Anyone have one that they would recommend? If so, where did they mount the sensor(s) as well as the display unit? Cost? I imagine having the display mounted in one of the two containers under my stereo (no NAV). The goal would be to flip the door down in the event I was pulled over, only I am not sure how noticeable it would be to me down there, when it went off. Thoughts? Thanks.
Old Jan 28, 2006 | 12:58 PM
NFLblitze1's Avatar
Youse Gots Sacked
i have that set up hardwired...along with some other switches...its like a stealth switch panel
Old Jan 28, 2006 | 02:04 PM
jlkdoh's Avatar
Please elaborate. Which detector? How effective is it and do you use the top or bottom container? Both? Whatever insight you have would be helpful. Thanks.
Old Jan 28, 2006 | 02:45 PM
NFLblitze1's Avatar
Youse Gots Sacked
Old Jan 28, 2006 | 04:01 PM
jlkdoh's Avatar
nice! Thanks. Anyone else?
Old Jan 28, 2006 | 06:15 PM
NFLblitze1's Avatar
Youse Gots Sacked
i think u might be looking for something more stealth of a radar detector....search for STREETEFFECTZ.......hes incoporated radar detectors into the REAR VIEW MIRROR and it looks very stealth
Old Jan 28, 2006 | 06:26 PM
Golf_Nut's Avatar
5th Gear
not sure why you would want to go stealth unless you live in DC or Virginia. those are the only states that make radar detectors illegal.
i'll post my setup later tonight. went to take a few shots with the digital camera and it was dead! I will charge it and post
Old Jan 28, 2006 | 06:30 PM
NFLblitze1's Avatar
Youse Gots Sacked
sometimes if u get pulled over with a radar detector cops will take it as an insult and it will reduce ur chances of getting out of a ticket because having a radar detector gives off the impression that are a common speeder....
Old Jan 28, 2006 | 06:32 PM
Golf_Nut's Avatar
5th Gear
they would be right!
i can't drive 55................................
Old Jan 28, 2006 | 06:33 PM
NFLblitze1's Avatar
Youse Gots Sacked
thats why you'd want the stealth look
Old Jan 28, 2006 | 06:47 PM
Golf_Nut's Avatar
5th Gear
ok how do you post pics in here..
Old Jan 28, 2006 | 07:01 PM
NFLblitze1's Avatar
Youse Gots Sacked
http://www.imageshack.us
http://www.photobucket.com
Old Jan 28, 2006 | 07:26 PM
Golf_Nut's Avatar
5th Gear
i took my car to the acura dealer since i didnt want to try and do this myself. paid $120.00 for installation.
they wired into my eletrical system so when the key is turned on it starts up.
as you can see in the 3rd pic they fished the wire through the vent. he said he had to pull the front console(pic 1) so he could place the controler in the bottom slot. you dont need this but i like the fact that i can press the mute since my radar detector is so sensitive i get false alams alot.
Old Jan 28, 2006 | 09:26 PM
jlkdoh's Avatar
NFLblitze1 has it right. In the event I get pulled over, I would prefer the cop not know I am carrying a detector. I am looking for one with a remote sensor (i.e. wire) poking out near my front license plate with the only other visible element being the UI, that I hope to be able to drop the door on. Also, I don't want a detector sitting in my window so any low-life gets the urge to knock out my window... happened once some years ago. Thanks.
Old Jan 28, 2006 | 10:31 PM
Spider0079's Avatar
I have a K40 window mount radar hidden behind my rear view mirror. I had it hardwired to a constant power source so it goes on with the car and off with the cra.
Old Jan 29, 2006 | 12:02 AM
vp911's Avatar
Are you talking about the one that would go in the front grill? Completely hidden unit? If so, check the 3G Garage for the ZR3 installation I did. That is for a laser jammer, but the radar detector system would be installed virtually identical to that.
Old Jan 29, 2006 | 01:09 AM
jlkdoh's Avatar
vp911, you got it! Thanks. Quite impressive. Not only the work you did to install, but to document for the rest of us. When I do this, your post will be my bible... of course I won't hold you liable for my screw-ups. Question, with the Valentibne, is the rear sensor of much use? Necessary?
Old Jan 29, 2006 | 01:12 AM
vp911's Avatar
Glad to be of assistance.
What I installed was a laser jammer - it will jam laser signals only. The valentine only detects radar and laser. So, in reality, yes both the front and rear sensors for the laser jammer are necessary.
In your situation, if you are doing only radar, I don't know if there are any hidden radar systems that have a rear sensor.
chrisr
Dec 4, 2015 02:17 AM
sockr1
Oct 1, 2015 01:31 AM
Sep 17, 2015 09:01 PM
TxRzrBk
Sep 17, 2015 01:07 PM
siularbar
1/2G MDX (2001-2013)
Sep 11, 2015 10:40 AM
