Hardwire Radar Detector -> broken NAV?
Old Jun 8, 2010 | 09:42 PM
ReD-BaRoN's Avatar
Hey folks,
Can you tell me if you think these two things are related?
I was hardwiring my radar detector into the switched power in the area powering the rear-view mirror and sun roof switch. The next time I powered on the car, I got an error saying something along the lines of DVD Disc Reading Error - Consult Your Dealer.
I think it's coincidence, but maybe it's not. I removed the hardware (inviscord) but the problems remain. I ejected the DVD, inspected it (no scratches) and put it back in and still the error remains.
Any ideas, on if this can be fixed with dropping lots of $$?
Thanks!
Old Jun 8, 2010 | 10:36 PM
LaCostaRacer's Avatar
I hardwired my detector with no Nav issues. Check your fuses- perhaps one blew.
Old Jun 9, 2010 | 08:37 AM
d-townhakuzo's Avatar
It is not nav related...I think it maybe a fuse as well. When in doubt, check the fuses first.
Old Jun 9, 2010 | 09:43 AM
MRTaylor's Avatar
+1 on what they^^ said. It's probably caused by either a blown fuse, or the fact that you could have just bumped one the wrong way or something while installing your radar.
Old Jun 9, 2010 | 07:48 PM
JORTS's Avatar
keep us updated on this....also let me know how the Invisicord worked (hopefully it didnt cause the NAVI issue!)....this is the first i have ever heard of the Invisicord and i am REALLY interested in getting one cause i am looking at get a beltronics v940 off of amazon for $125
Old Jun 10, 2010 | 09:27 AM
Cyberdemon's Avatar
RE Hardwiring, running a regular wire up the A pillar and across the top of the windscreen is also extremely easy to do and doesn't require modifying anything permenantly.
I had an invisicord on my Vette and was less than in love with it. I didn't want to solder it and over time it kept loosening up and cutting power to the mirror.
OP: Can you access the nav diagnostics (Hold Map, Menu + Cancel)? If so you might be able to run one of the self checks, that may show you what is failing.
Also does the DVD drive still have power? IE can you eject the DVD?
Old Jul 14, 2010 | 07:23 PM
raf1919's Avatar
Originally Posted by ReD-BaRoN
Hey folks,
Thanks!
can you tell me how you took apart that area or where excatly you wired too? i want to do the same.
Old Jul 14, 2010 | 08:32 PM
ReD-BaRoN's Avatar
This is the thread I followed since it had great pics. Worked great.
https://acurazine.com/forums/showpos...0&postcount=13
ITSJESTER
17
Dec 6, 2018 02:29 AM
Jul 16, 2017 07:33 AM
ITSJESTER
4G TL Photograph Gallery
Oct 13, 2015 12:53 PM
juanrl
Sep 29, 2015 03:25 AM
