HandsFreeLink - DIAGNOSTIC MODE???
Old Dec 5, 2004 | 10:49 PM
nelhelou's Avatar
My 2004 TL is stuck in HandsFreeLink Diagnostic Mode and will not turn off. I read already how it is a test that runs for 10-15 seconds and then goes back to normal but mine seems to be stuck. I can't listen to music or anything. Here's what I have already tried, to fix the problem:
- I have tried holding the "Back button" down for 10 seconds like I have read.
- I have tried turning the car off and turning it back on again
- I have let the car sit over night
- I have turned the phone on and off
- I have held the Select/Restart button down
- I have messed with the < INFO > button
Nothing has worked and it sounds like something is wrong. This all started when I started programming my phonebook in the TL. I'm going to try to take it into Acura Monday, but I was wondering if there is an easy/quick fix to the problem.
Help,
Nick in Santa Rosa, CA
Old Dec 5, 2004 | 11:18 PM
rexwui's Avatar
Try disconnecting and reconnecting your battery before bringing it in.
Old Dec 5, 2004 | 11:39 PM
DaT1PiNoYduDe's Avatar
TL Techy
If you do that, make sure to have your Navi and Radio codes ready
Old Dec 6, 2004 | 02:07 AM
nelhelou's Avatar
Fixed: HandsFreeLink - DIAGNOSTIC MODE??? Reply to Thread
Okay so I unplugged the battery and that seem to fix the problem. Just an additional note that I did not have to put in a code to re-access the sound system or navigation.
Thanks,
Old Dec 6, 2004 | 02:39 AM
6mtV6's Avatar
I6
I had to disconnect the battery once to reset my HFL. I didn't have to input the code for the sound system and navi also.
Old Dec 7, 2004 | 01:29 AM
wolftag's Avatar
Don't disconnect the battery. Just pull the fuse panel door above the hood release in the driver's footwell. Locate fuse #10 and pull it for a few seconds. This will cut power to the HFL unit.
Old Jul 14, 2006 | 09:53 PM
jq2's Avatar
jq2
Smile Fuse 6 or 10 - one of them worked for me - thanks!
My '04 was off for 2 hours with the doors locked and the MID still showed "HandsFreeLink Diagnositics".
I found this suggestion to pull #10 first. After I pulled it, the MID still showed same, so I came back in the house and found this thread so I pulled the #6 fuse and the MID didn't change! However, when I turned the car back on, the HFL was no longer locked up. So, one of them worked for me! :-)
Thanks to you both - and to this forum, in general! I'll be contacting my dealer about the service bulletin. Thanks to loud_whispers for the recall list!
Old Apr 22, 2010 | 10:18 PM
jjmott's Avatar
5th Gear
I had the same problem. I tried fuse 10. That didn't work. I then tried fuse 6. That worked. The whole process took 2 minutes.
Old Apr 22, 2010 | 11:26 PM
kurdtcobain's Avatar
my 2004 TL's HFL got stuck in use and has been like this for 2 days. Nothing works as stated above. I will try the fuse troubleshoot; however, I did talk to acura and they said I need a new bluetooth system which will cost $450 just for parts. All I can say is I hope the fuse fix works. Anyone run accross it freezing in use?
Old Jul 22, 2010 | 11:03 PM
Mopos's Avatar
What does pulling the fuse do? I pulled #'s 6, 7 and 10 with no luck. Maybe yours just starting working and the fuse had nothing to do with it. ??
Biggie_B
May 27, 2025 05:51 PM
4drviper
Apr 23, 2025 07:13 PM
Jul 16, 2017 07:33 AM
hashbrown
Sep 29, 2015 12:13 PM
