Handsfree pairing problem
Old Aug 11, 2008 | 10:23 AM
joesegal76's Avatar
I just got the Iphone 3g and have successfully paired the phone. However the next time i start my car it won't reconnect with the phone. It shows the handsfree-link as connected under bluetooth options on the phone but the car does not connect. Is anyone else having this problem?
Old Sep 23, 2008 | 10:15 AM
joesegal76's Avatar
sorry to bump but does anyone have this issue and are there any solutions?
Old Jan 13, 2009 | 02:27 PM
encryption's Avatar
I have the exact same problem. I have a blackberry 8700G
Old Jan 13, 2009 | 04:13 PM
Trew's Avatar
how ironic that your username is encryption. have you tried turning off encryption on the connection in your phone?
also make sure the device is "trusted" and "allow connection: always" in your phone.
Old Jan 13, 2009 | 04:41 PM
encryption's Avatar
After I made my post above, I found a thread that said disable encryption. I will try it on my way home
Thanks for responding though.
Old Jan 13, 2009 | 05:56 PM
Trew's Avatar
Let us know if this works, please.
Old Jan 14, 2009 | 08:06 AM
encryption's Avatar
After I turned encryption off in my BB, it paired instantly when I turned on the car both times when I drove home from work and back to work this morning. So far so good
Old Jan 14, 2009 | 08:18 AM
Trew's Avatar
Awesome! Thanks for the feedback.
Old Jan 16, 2009 | 11:35 PM
samdrvsatl's Avatar
Lol i cant even make my phone pair with my car i always try to set it up but it turns on the a/c or it gives me the time so i just gave up and use the speaker
Old Jan 17, 2009 | 03:28 AM
tc_terencec's Avatar
I MAKE NO SENSE
You have to make sure that your phone supports the HFL profile (a list of settings which make it compatible with the car). Some carriers (such as Bell here in Canada) like to "Cripple" their cellphones' bluetooths, and thus only allowing certain bluetooth devices to connect successfully
Old Jan 17, 2009 | 07:34 AM
Trew's Avatar
Sounds like you're hitting the wrong button. Make sure you hit the button that looks like a phone receiver. Its higher up on the steering wheel (it pushes away from you, not toward you). Press that one and say "Phone Setup", then say "Pair".
SidhuSaaB
May 30, 2020 12:40 AM
LoneRonin
Jan 4, 2016 01:03 AM
Matthew Purpura
Sep 25, 2015 06:10 PM
95oRANGEcRUSH
Sep 25, 2015 12:50 PM
rboller
Sep 23, 2015 02:49 PM
