Hands free link problem
Old Oct 3, 2008 | 04:29 PM
big_mac65's Avatar
B-MAC
OK so i have a little problem with my Hands Free Link System on my 06 TL. I have had so many phones paired up with it that wont hold anymore. I try to delete a phone an it goes all the way to where you say "okay" to continue deleting. Only problem there is when i say "okay" it loops back to the beginning and wont delete the phone. I had someone tell me that i should just clear the system, so i tried it and guess what the same thing happened. It would get all the way to where it asks you to say "okay" to continue, and i say it and then it starts all over. So my question is has anyone else had this problem and if so were you able to fix it???
Old Oct 3, 2008 | 08:47 PM
csmeance's Avatar
hold the talk and end button together for 10 secs. it should go into diagnostic mode if i'm right...
Old Jan 27, 2009 | 08:44 PM
Xpditor's Avatar
Tried that. It didn't do anything.
Old Mar 4, 2009 | 12:40 PM
GoBig's Avatar
Any resolution...I'm having the same problem!
Old Mar 4, 2009 | 09:57 PM
Xpditor's Avatar
Yes.
The dealer replaced my HFL module. The part was going to cost $600 plus labor. It's in the overhead console.
But Acura ate it. I was past my warranty time wise but still under on miles and I had reported the problem a while ago. There is a Technical Service Bulletin since some of the early modules went bad on the 2004-5s.
Suck up to your dealer if you are over warranty. Ask them to ask Acura to do it since you are a good customer. Remind them of the TSB. At the end of that TSB it says that if the customer is past warranty, they will look at each case and consider covering it as a "good will" gesture.
Old Mar 4, 2009 | 10:35 PM
PeterUbers's Avatar
has anyone tried just unplugging the BT module in the overhead console there... and letting the static memory clear out that way .. then try re-plugging it in... that console is not that hard to get at .. ???
Old Mar 9, 2009 | 12:56 AM
Xpditor's Avatar
Peter,
I did essentially the same by disconnecting the battery several times to reset the HFL when it locked up in the pairing mode.
That was successful in resetting and unlocking everything. But, still it would not pair.
Another symptom was when I tried to edit the phone book. When I asked it to list the names in the phone book, it said "Phone Book is Empty".
When I tried to add a contact to the phone book, it said, "Phone Book is Full".
It was messed up big time.
Disconnecting the battery did not change that.
Old Mar 9, 2009 | 08:27 AM
rodneyc77's Avatar
Retired!!! ON TOP!!!
you guys have to use a completely different NAME when pairing a new phone... it worked for me...
Basically when the system asks you to name the phone you're trying to pair... use a completely different name (something not previously used)....
Old Mar 10, 2009 | 11:52 AM
pilotman28's Avatar
Did you try resetting the whole system? I was having the same problem yesterday but after I cleared the system it works even better than it did before.
Old Mar 10, 2009 | 03:32 PM
Spiritman's Avatar
Man of God.....
Cool
Man I was just going to say that!! That, I think is your answer. Do the "clear command"!
Old Apr 8, 2009 | 12:19 PM
ando1brett's Avatar
6th Gear
I've encountered the same problems with my 04 TL and am still looking for a solution. My phone will not pair. I can not get the system to delete any phones. When I try to pair a phone, or clear the system, it locks up and the only way I've been able to unlcok is by disconnecting the battery.
Acura said the HFL needs to be replaced, but quoted me $1,200. I'm desperate and trying all other options I can think of as I don't think I'll pony up that much coin to fix it.
rockyboy
Aug 4, 2024 10:35 AM
oo7spy
Jun 19, 2023 12:48 AM
IIDXholic
Sep 19, 2015 10:18 AM
ivegotthenav
Sep 11, 2015 07:51 PM
RK_AcuraTL
Sep 5, 2015 02:26 AM
