Factory system integration
Old Feb 9, 2014 | 03:33 PM
safo522's Avatar
i bought all new speakers, 3 amps. 1 amp for the door speakers and the rear deck speakers. 1 mono amp for the sub and 1 small amp for the center channel speaker.
i also bought a rockford fosgate 3sixty.3 for the system integration.
i know that i cant upgrade the head unit in the 3g TL so i decided to go with the 3sixty.
i want to completely bypass the factory amp but i am very confused of how to connect everything together.
any help would be very appreciated
thank you.
Old Feb 9, 2014 | 06:21 PM
Vlad_Type_S's Avatar
Registered Bike Offender
https://acurazine.com/forums/3g-tl-audio-bluetooth-electronics-navigation-94/diy-aftermarket-amp-install-speaker-install-audiocontrol-matrix-install-w-pics-580314/
https://acurazine.com/forums/3g-tl-audio-bluetooth-electronics-navigation-94/part-3-amp-install-audio-control-matrix-speaker-replacement-581820/
Originally Posted by Vlad_Type_S
Let me break it down for you bro!!
Ignore the markup on that pic, I only mean to show you the schematic so you can see the colors of the wires between the factory head unit and amp. Those two threads have all of the information you need. Good luck bro, and post some pics of your work! Sounds like an awesome project!
Old Feb 9, 2014 | 07:17 PM
safo522's Avatar
thank you i really appriciate it man!
Old Feb 13, 2014 | 09:08 AM
safo522's Avatar
If i bypass my factory amp will i lose my voice controls and bluetooth over the speakers?
Old Feb 13, 2014 | 10:09 AM
pohljm's Avatar
Keep he center channel on OEM amp so you will hear voice prompts. Other than that your good.
Old Feb 13, 2014 | 11:47 AM
safo522's Avatar
ok thank man.
but if i bought a 75W x 2 RMS amp for the center channel because i replaced the center speaker . could i just connect it to that and would i still be able to hear the voice prompts and bluetooth?
or should i return that amp and just run the center channel through the stock amp?
Old Feb 13, 2014 | 02:20 PM
pohljm's Avatar
As long as u use the center channel output to that amp you will be fine. There isnt much material playing thru the center channel so that amp may be overkill unless your trying to maintain surround sound
Old Feb 13, 2014 | 05:26 PM
safo522's Avatar
yeah i am trying to maintain the 5.1 surround by replacing and using all the speakers that are being used now. so i had to buy a small amp for the center channel.
Old Feb 13, 2014 | 06:33 PM
pohljm's Avatar
what speakers?
Old Feb 13, 2014 | 08:21 PM
safo522's Avatar
the front right and left door speakers, the two rear deck speakers and the center speaker and of course the tweeters
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
agupta3224
Sep 22, 2015 08:08 PM
