Factory sub & amp???
Old Oct 9, 2013 | 10:36 AM
mrwhitneysTL's Avatar
3rd Gear
Is it possible to put an aftermarket sub in truck but have it wired to the factory amp so I have sub control and maybe a little better sounding bass?
Old Oct 9, 2013 | 11:18 AM
pohljm's Avatar
You will never be happy with the sub output using the factory amp. You can add an amp and sub and still retain sub control from the HU.
Old Oct 9, 2013 | 04:22 PM
MarcoNorthPolo's Avatar
KCCO
^ What pohljm said. I believe there is only 40w going to the stock sub, so that wouldn't really do much for an aftermarket sub.
Old Oct 16, 2013 | 08:42 AM
killer8rican's Avatar
Is there a how to? i havent found it.
Old Oct 16, 2013 | 07:08 PM
niebur3's Avatar
^^^How to what?
What the others have said, however you can use the signal wires before or after the amp and route them to an aftermarket amp via a Line Driver or Line Out Converter, which will still give you control of the sub volume via the head unit.
Old Oct 16, 2013 | 09:48 PM
tl_604's Avatar
8th Gear
https://acurazine.com/forums/3g-tl-audio-bluetooth-electronics-navigation-94/diy-aftermarket-amp-install-speaker-install-audiocontrol-matrix-install-w-pics-580314/
Old Oct 16, 2013 | 09:49 PM
tl_604's Avatar
8th Gear
wiring subs and amp with stock headunit is really simple, everyone uses line out converters
4drviper
Apr 23, 2025 07:13 PM
Jul 16, 2017 07:33 AM
InFaMouSLink
Oct 30, 2015 09:43 AM
Birdflunuggetz
ILX
Sep 28, 2015 01:14 PM
