Factory 2004 dash tweeter grille
Old Jul 10, 2011 | 09:03 PM
neverleaveitstock48's Avatar
3rd Gear
I did something stupid and started a jl component install before I read into all the work I had to do and decided not to do it. However I ruined my factory tweeter grilles. I still have the oem tweeters but kneed the clips and the grilles. Can anyone help me out with some parts? It'd be much appreciated. Thanks!
Old Jul 10, 2011 | 10:27 PM
Nick337's Avatar
www.acuraautomotiveparts.org, you can get the speaker grills by itself its like 10 bucks or so whenever i ordered it a while back.
Old Jul 10, 2011 | 11:38 PM
Trunk Monkey's Avatar
Coolest A-zine Member
I wonder if the vendors can get these? Id like to pick up some to mount tweeters on instead of hacking up the factory ones
Old Jul 11, 2011 | 05:50 PM
Nick337's Avatar
im pretty sure they can jus give them the part number.
Old Jul 11, 2011 | 07:18 PM
3rd Gear
Thanks guys, Ill check it out!
Old Jul 11, 2011 | 07:26 PM
3rd Gear
You wouldnt happen to have a part number for the tweeter grille would you?
Old Jul 11, 2011 | 07:54 PM
Nick337's Avatar
77132-SEP-A00ZA right side
77137-SEP-A00ZA left side
Old Jul 12, 2011 | 09:02 AM
niebur3's Avatar
Why is installing a component set a lot of work? No different than an other car.
Old Jul 12, 2011 | 09:18 PM
I hate cars's Avatar
Give me a day to look but I can give you my brand new ones free+ shipping. I ordered them then realized the Dyns drop almost perfectly in the stock hole and I didn't need them. Not sure where they are but I'll look if you want.
Old Jul 13, 2011 | 08:25 AM
Lemme check with JDA and see if those ID CXS tweets will drop right in.
Old Jul 13, 2011 | 08:33 PM
MistaWet's Avatar
Since we are discussing speakers, are the door speakers tweeter less or do the highs come from the dash tweeters only?
Old Jul 13, 2011 | 09:06 PM
If they're anything like the CTX tweeters you can easily make a hole in the existing grills and use the hardware to mount them. It's a 5 minute job and looks great. That's what I did with mine and it almost looks factory, not something the passengers would notice. I got a little more clarity with them mounted this way vs under the stock grill. That's the whole reason I bought new ones, because my stock ones had holes in them from the mount.
Old Jul 14, 2011 | 12:38 AM
crazyjr79's Avatar
I did the same thing. I took out the old tweeter, used my dremel to cut out a 2" diameter circle and dropped in the new Polk Audio component tweeter. Looks factory, clean, and ^^ is right...sounds better outside than inside. Tweeters are dirrectional, and therefore you don't want to have any kind of obstructions.
Old Jul 14, 2011 | 09:42 AM
Is it just me...or is the soundstage (w/o processing) mostly on the drivers side with tweeters flat and in factory location? I've been trying them angled and all which ways..I feel like I can't hear the passenger tweeter when its flat in the factory location (pointing at windshield)
Old Jul 14, 2011 | 04:45 PM
jda123's Avatar
Dogmatic Dinosaur
The CXS tweeters are larger than the CTX - weighs about 3x as much too. You cannot holesaw for the CXS with the stock tweeter grill because you will have too fragile of a thin rim left.
The CXS fit in the stock hole pretty well, but a piece of HDPE or Starboard would make a nice thin ring. Nobody would every notice but you if you never made a ring to mount them on. You can oftentimes buy scrap HDPE or starboard from a local plastic company for next to nothing.
Old Jul 14, 2011 | 04:48 PM
jda123's Avatar
Dogmatic Dinosaur
This depends on the tweeter, of course. I like domes to be angle mounted just a touch off axis, but every taste is different. The higher quality the set, the less you will notice this... but it still might be noticeable.
The balance is the poor-mans processor for this. So is the gain if you bridge an amp. I have also heard of people doing +1 DB on the passenger side... but lots of sets are not that granular for tuning.
Old Jul 14, 2011 | 04:53 PM
jda123's Avatar
Dogmatic Dinosaur
In the stock setup, there is a 6.5 inch mid range speaker in the door and a 3/4 or 1 inch tweeter in the dash. Both of these work together to produce 99.6% of the frequency range that our radio produces. Roughly half of the vocals and instruments can/will come from both of the speakers.
There is no tweeter in the door - just the dash. There is no tweeter in the rear speakers either.
4drviper
Apr 23, 2025 07:13 PM
tsx_boy
Dec 13, 2019 08:33 PM
iRaw
ILX Photograph Gallery
30
Aug 5, 2016 04:41 PM
rhdune16
Sep 28, 2015 11:31 AM
2Quik
Sep 23, 2015 01:03 PM
