ELS stock speaker specs - size/imped/depth
Old 05-23-2009, 11:37 PM
  #41
jnc2000's Avatar
Where bouts are you in PA?
What RTA do you have? O-scope? bench setup do you have?
Old 05-23-2009, 11:39 PM
  #42
jnc2000's Avatar
found one answer: Lancaster PA
Old 05-24-2009, 12:26 AM
  #43
Thuneau's Avatar
I use Professional SMAART measurement system with Earthworks M30 microphone and a Presonus Firebox interface for frequency and impedance measurements.
I use software called lspCAD for passive crossover design and simulation.
I also use digital crossover processing software called Frequency Allocator that I designed and offer for sale. A few of my customers are even running it on carputers for their speaker processing. I don't have a carputer, but would like to try one one of these days.
Old 10-30-2009, 04:56 PM
  #44
ScorpioNAtl's Avatar
So when I walk in and ask the Rockford dealer what he has to tune my 360.2, the installer should be able to show me his tuning program or is the bluetooth PC interface the actual tuning software?
Old 10-31-2009, 10:34 PM
  #45
paulonfiya's Avatar
i just install focal 165a1 6.5 component front and back speaker, and sound realy good.. now i wanna run it on 4chan amp..
Old 10-31-2009, 10:44 PM
  #46
paulonfiya's Avatar
focal 6.5 allround model number 165a1 350$ pair and they sound realy good
Old 05-25-2010, 10:15 AM
  #47
robocam's Avatar
That would apply in ideal situations, but...
The key words here are "well designed and balanced," both of which the system in the TL are not. Changing the tweeters or door speakers will most likely improve the situation no matter what brand/model is chosen.
Sometimes you don't need fancy equipment to determine whether something is better. You've got ears. If it sounds better to you, then it's better.
However, I totally understand where you're coming from. Ideally, someone with an RTA would be adjusting your 31 band EQ, but most people aren't going to go that far. Trying different speakers and tweeters is a perfectly OK thing to do in most car stereo situations.
Actually, here's what I wish for someday.
http://www.alpine-usa.com/product/view/pxe-h660/
Originally Posted by Thuneau
A well designed and balanced system, has crossover components matched to speakers in such way that the combined response is smooth. Dropping in a new component, without compensating for it's impedance and natural response by also matching and installing new crossovers is a bad practice. It never works out.
So while a new tweeter might sound louder or brighter than the old one, and therefore "better", you almost certainly made the system worse- less true to the music.
Be really careful when messing with audio components. Try to find someone with audio measuring equipment and knowledge how to use it to confirm that you are indeed improving things when modding.
sockr1
10-01-2015 01:31 AM
DiamondJoeQuimby
09-10-2015 11:40 AM
alan_rich
09-07-2015 11:08 PM
iRaw
ILX
09-05-2015 12:10 AM
Quick Reply: ELS stock speaker specs - size/imped/depth
