DIY Grounding Kit
DIY Grounding Kit
Has anyone done this yet?
http://www.edesignaudio.com/edv2/pro...roducts_id=165
3 ft. ground to chassis
4 ft. ground to engine block
8 ft. power to alt
It's supposed to help ground the car better, and help a bit in throttle response. I'm sure I could pick up enough wire and connectors from local store for about $15 or less...Any comments?
8 ft. power to alt
ah the Big 3. works great in most cars. the reason its pricey is the thick and heavy duty wire. you can tjust pick up any type of wire. Audio wires are very durable.
i'd get a 0 gauge wire, 4 gauge is about stock size.
On my RSX, yes. Also b/c i have an audio system, Hondata Kpro, and both require SOLID and GOOD grounds. It makes the electrical system fluctuate a bit easier and everything runs smoother.
Now the TL is drive by wire, so its electrical, so theres a strong possiblilty that you'll see a slightly faster throttle response and smoother acceleration. I plan to do a simple grounding kit with leftover audio wires i have.
Originally Posted by 06WDP-TL
...Now the TL is drive by wire, so its electrical, so theres a strong possiblilty that you'll see a slightly faster throttle response and smoother acceleration. I plan to do a simple grounding kit with leftover audio wires i have.
Once the engine is running (and the alternator is charging), the drive-by-wire system would continue to work even if you disconnected both of the "grounding" wires (though that would certainly mess up other systems on your car, so I can't really recommend that you try it).
I really have no experience with grounding and the electrical system of the car, besides car audio.
There were a few people that did this, or similar grounding mod's and had improvements on throttle response.
I have the Sun hypervoltage groundign kit on mine... I did notice a smoother throttle response WITH VSA on...
With VSA off, no difference at all...
I have a second grounding kit if anyone is interested...
emailnatec
29
09-28-2018 04:27 PM
GWEEDOspeedo
01-15-2016 10:39 PM
