DIY DVD Install
DIY DVD Install
Hi everyone,
I've recently acquired a 2007 TL Type-S and was interested in installing a DVD player in the front dash where there is currently a pocket directly in front of the shifter.
I have done quite a bit of research here on acurazine and found some information on how to do a DVD player install. However, I have only found one thread related on installing a player in this pocket that i'm interested in putting mine in and the thread does not have any instructions on how I could do it myself.
So my question is if anyone here can help point me in the right direction for finding a DIY for installing a DVD player in this front pocket, with directions one wiring, switch installations, needed equipment etc. all in one place, and of course preferably with some pictures?
I would greatly appreciate any help anyone could give me.
Thanks!!!
Mike
Thanks!!!
Mike
I'm working on a very detailed DIY that I'm going to try to post tomorrow. Unfortunately, I didn't put my DVD player in the area you plan to and I don't have any pictures (my camera died on me). But I still think it would be very helpful. Keep an eye out for it tomorrow. I can post a link to it in this thread. I hope it will help you out.
Also - your s/n is misleading if your name is Mike.
yeah..i'm still interested in your write up...i'm sure it will be helpful. If you can post a link to it in this thread as well that would be great!
yeah...i know the s/n is misleading...back in 2005 a good friend of mine bought a acura..and we were looking something up and in the process created a username on this forum for her (her name is Jessica). I must have used my email address back then. I had forgotten about that until earlier today when I was creating an account for me and realized that I had her account under my email address...I didn't see a way to change my user name and it was too much trouble to completly try to delete the original account and do a new one for me..so...lol..long story...I apologize!
thanks...Mike
thanks...Mike
thanks...Mike
Can you close your cubby hole door? It looks like you can't. I've seen an install on here where someone can fully close their door. I love this, good job, but I couldn't bring myself to hack up my car. I just opted to have the DVD player in the trunk.
I have seen both..where the doors can be closed and where it can't close...I think to get it closed you have to dremel off the metal bar behind the cubby hole...and part of the side of the cubby..not sure. Thats part of why i'm looking for a DIY...so I can get this done..as well as know what wires to wire where etc...
I installed the dvd player in the cubby hole but no diy, sorry. The metal bar can be removed by bending it up and down repeatedly till you weaken the spot weld. Repeat on the other side, its less messy and no metal shavings compared to dremel. The downside is i had to sacrifice the ac duct behind it to accomodate the dvd player. I had to cut a rectangle and build a box inside the duct so it restricted the air flow. Changing the duct is easy and only $17. Will be buying it for future use in case it gets hard to find. Btw i used the myron and davis unit. Something to keep mind.
as for a DIY, i dont have one because it was done by the prev owner. however i've taken apart the panels and checked that all the work was done very professionally and no sign of wires showing anywhere
i dont have a cubby anymore, it was completely removed for the dvd player.
Take a lot of dremeling but there are several members that have installed 1/2 din dvd players in the center with the door being able to open and close. I did not have to relocate the a/c ducts, but did have tor rearrange the circuit boards inside the dvd player and modify the rca cables due to the dvd player rubbing on the a/c duct.
DOOR OPEN
DOOR CLOSED
DOOR OPEN
DOOR CLOSED
I appreciate you adding the link so I can see your write up...I've started reading some of it..yeah..wish that your camera was working at the time..it would have made a world of difference..but your write up is definitely better than most of the ones that i've been able to find online...so..currently reading it to see what it all entails.
I will be keeping my end of the bargain up!!!
mike aka..Jessica
You'll have to use a website to host photos. A lot of people use photobucket or imageshack. I prefer imageshack because it's not blocked by my firewall at work. .
Yeah, sorry about the no pictures. I was really disappointed my camera didn't work. But I did my best to paint the picture in words. You might have to read something over a couple of times to get it in your head, but if something doesn't make sense just post in the thread and I'll try to better explain what I meant!
cycdaniel
12-17-2019 10:58 AM
BoricuaTL
04-08-2016 01:08 PM
pistacio
09-26-2015 09:45 AM
