Disable Bluetooth/fix battery drain?
Old Nov 28, 2015 | 06:21 PM
leedogg's Avatar
RAR
So I suspect my battery is draining cause of a bad Bluetooth. Does anybody know if it's possible to disable BT in the car?
I was looking at pics in this thread:
https://acurazine.com/forums/third-g...onsole-746609/
and was wondering if it's possible to disable BT by unplugging one of these plugs?
Is the center component with the white tape the Bluetooth unit?
Old Nov 29, 2015 | 12:22 AM
Will Y.'s Avatar
Registered but harmless
Yes, it's easy to disconnect the HFL/Bluetooth module-- see post numbers 212 through 222 of the following thread: https://acurazine.com/forums/audio-b...-792642/page4/.
No, I think the center component part of the map lights is the Homelink opener system.
In your photo, that tan plastic bezel/surround bolted to the roof contains the HFL unit. Post #212 in the thread above shows the bezel and unit.
Old Nov 29, 2015 | 01:23 AM
leedogg's Avatar
RAR
Thanks, took a bit a rooting around those thread links but I finally found a service bulletin with the write up on removing that overhead console.
https://app.box.com/shared/ahv7hm987...GAN_1296799475
Rae Rad
ILX Photograph Gallery
57
Jan 19, 2016 02:55 PM
acuraST
1G TSX Problems & Fixes
Dec 21, 2015 03:12 PM
GaDunk
1G RDX DIY & FAQ
Dec 9, 2015 03:36 PM
ATL4
Nov 30, 2015 08:42 PM
bg2128506
Nov 25, 2015 03:03 PM
