Dice Ipod Install
Old Apr 18, 2008 | 07:58 AM
4DGSR's Avatar
Question Dice Ipod Install
I searched the forums and could not find a clear answer on the XM unplug to get the text display. So here is my question, where do I keep it unpluged? Back of the deck or the trunk? When I have the Dice unit plugged into the deck and the Y adapter left empty, I can not access the Ipod by hitting the XM switch. I can only access it from the CD-C function. So what am I doing wrong?
I do have the dip switches in the down postion (which is the on postion) when I have the Y adapter plug left empty. Any help would be greatly appreciated.
Old Apr 18, 2008 | 08:20 AM
nalek's Avatar
Unplug the XM in the trunk
If the DICE is showing up as CD-C, then your jumpers are set to that. Make sure you set them to the TEXT mode.. I dont remember which way that is, but that is defiantly a jumper problem
PS. If you have a 2007-2008, you'll lose AcuraLink and all HFL functionality of your navi screen when you unplug the XM Box.
Old Apr 18, 2008 | 11:23 AM
4DGSR's Avatar
okay, so unplug it from the xm brain in the trunk?
Old Apr 28, 2008 | 01:32 PM
4DGSR's Avatar
this unit still does not work with the dip switches set to ON, in the down position. Roar!!
Old Apr 28, 2008 | 02:11 PM
rodneyc77's Avatar
Retired!!! ON TOP!!!
looking at the dice unit... where the dip switches are.... down down & UP UP...
Old Apr 28, 2008 | 04:45 PM
zkw1102's Avatar
6th Gear
where is the xm box
Old Apr 28, 2008 | 04:47 PM
zkw1102's Avatar
6th Gear
where in trunk? i am doing this install tommorrow
Old Apr 29, 2008 | 08:12 AM
nalek's Avatar
Its on the right side, inbetween the rear quarterpanel and the trunk lining. Just pull the lining back, and you'll see it mounted to a vertical support. 3 bolts
Old Apr 29, 2008 | 08:28 AM
t0talacuratl's Avatar
Green Machine
I had mine installed as well, but can only use the CDC button and no steering wheel control. Eventhough I'm a non-nav, is that right?
Old Apr 29, 2008 | 01:04 PM
zkw1102's Avatar
6th Gear
I installed the dice today works great would highly recomend .
Old May 7, 2008 | 01:50 PM
4DGSR's Avatar
my unit must be broken. It does not work at all.
Old May 7, 2008 | 02:30 PM
mb190's Avatar
That really SUCKS!!!
Old May 14, 2008 | 06:54 PM
zoostation's Avatar
Where did you mount the Dice unit? Any pics?
Old May 17, 2008 | 09:37 AM
mellowgato's Avatar
7th Gear
I did this install last weekend.
I did not use the Y adapter, so I just unplugged the xm plug and plugged the dice module in there. I put the box under the air ducts near the front of the center console, in font of the shifter and just behind the two cubbies under the navi. I just had to move a couple wires and it slid right in there. A little double sided tape and it is secured to the bottom of the ducts.
No pics
cycdaniel
Dec 17, 2019 10:58 AM
giovane
2G RDX DIY & FAQ
Jul 8, 2016 10:46 PM
TxRzrBk
Sep 17, 2015 01:07 PM
Vejey Gandier
Sep 12, 2015 08:59 PM
ivegotthenav
Sep 11, 2015 07:51 PM
