Diagnostic messages in navigation system
Old Oct 23, 2011 | 02:10 PM
tonto340's Avatar
The short version:
Does anyone know how to clear diagnostic messages from the navigation system?
The long version:
On the way home from Joint Base Andrews last Tuesday I got DTC codes P0777, P01745 and a Vehicle Stability Assist 83 message. I ordered 1 28610-RKE-004, 2 28600-RKE-004 and 3 90471-PW7-A00 from Acura Carland in Georgia. The parts wil arrive Tuesday. I cleared the codes but the diagnostic messages still show up in the navigation system. Does anyone know how to clear the messages?
James
Old Oct 23, 2011 | 03:30 PM
04WDPSeDaN's Avatar
iWhine S/C 6MT TL
With car on, press and hold map menu cancel. A new screen will show up and you go to detailed diagnostics and pick the box marked xm. Some where in there is xm diag. Go through that and then you should see a bunch of other items in there will be diag messages and clear messages. This is all from memory right now, but its right in that menu so you will see it when there.
Old Oct 24, 2011 | 03:47 PM
Fatfrii's Avatar
i did not know this...good info! so there is no need to hook up an obd2 scanner if u have navi? damn i just spent 130 on 1 last week hahahaha there are other cars in my garage tho so its ok
Old Oct 24, 2011 | 05:23 PM
lsimmons's Avatar
I still think you need the OBDII scanner/clearer for the lights in your guages.... But maybe not
Old Oct 25, 2011 | 05:19 AM
tonto340's Avatar
The map menu cancel combination doesn't work in my 07 TLS. It worked once before so maybe one of the navigation updates changed the system.
Old Oct 25, 2011 | 08:21 AM
TecSavi's Avatar
Try this:
Hold "Map/Guide", "Menu" and "Cancel" for 5 seconds. This will get you to the diagnostic menu. Press the XM button on the bottom right and then press the bottom button to get a screen where delete diagnostic is an option. Once you press this you get a dialog box that says "Restarting Acuralink will require activation. Are you sure?"
Anyone one know if it is the NAV code or radio code that is required to activate Acuralink?
Old Oct 25, 2011 | 04:42 PM
tonto340's Avatar
Thanks. Messages cleared. I wasn't holding down for 5 seconds on the last try. Now if the new pressure switches fix the problem I'll be set.
Old Oct 26, 2011 | 11:08 PM
Fatfrii's Avatar
i do not see the XM button on the screen. i see "version" on the bottom right. maybe this is because i have the 2011 disc
Old Nov 18, 2014 | 12:51 PM
jeeva86's Avatar
'08 TL-S 6MT
I don't have the XM on screen button too. Which nav year do you guys have installed? I think mine is a 2011, not sure.
Old Feb 5, 2017 | 09:57 PM
dc2kid's Avatar
hey did anyone figure this out? do we have to have a active xm suscription, I got in the diagnostic menu but theres no xm menu to see the error codes,
EE4Life
Nov 27, 2024 05:36 PM
Feb 25, 2020 09:57 AM
Tim Giron
Mar 18, 2016 09:50 PM
DiamondJoeQuimby
Sep 10, 2015 11:40 AM
Gianni Formica
Sep 7, 2015 08:28 PM
