Diagnostic Message Delete
Old Apr 13, 2010 | 08:09 PM
NBP04TL4ME's Avatar
Stay Out Of the Left Lane
Does anyone know how to delete the diagnostic messages from the Nav?
Please read this for the background -
https://acurazine.com/forums/showthr...4#post11919264
So I have five messages (1 for each wheel and 1 for the system itself).
I read the owner's manual and it says only the dealer can delete the diagnostic messages, but I know there must be someone on AZine who knows how to get into or to the service menus to delete these.
Old Apr 14, 2010 | 08:16 PM
NBP04TL4ME's Avatar
Anyone?
Old Apr 15, 2010 | 08:46 AM
Crestwood1001's Avatar
You would need the tool that plugs into the diagnostic port
Old Apr 15, 2010 | 05:52 PM
TeknoKing's Avatar
You can easily delete the messages..
You'll need to evoke the diagnostic screen first, get in your car, turn the nav on, and hold down the "GUIDE", "MENU", and "CANCEL" buttons for about 5 seconds. The factory calibration screen will come up.
Then click on XM module, and you'll see the option to erase those messages. Believe it or not the diagnostic messages are stored in XM module.. dumb.
P.S. word of advice, be careful
Old Apr 15, 2010 | 08:03 PM
NBP04TL4ME's Avatar
TeknoKing - Thanks!
Very easy - but everything is easier when you know how to do it. I was carefull and did a little snooping around as well. Do you by chance know how to bypass or reset the PINs on the address book or home address? I bought my TL-S used and currently can't get past the prior user's PIN.
I can wait to go to the dealer, but thought if a fellow AZiner knows how to do this why not share?
Again thanks for your help.
Old Apr 15, 2010 | 08:22 PM
TeknoKing's Avatar
^ My pleasure. I'm not sure about the pin, I'd try disconnected the battery for 15 mins or so, just make sure to have your radio/navi codes.
Old Apr 15, 2010 | 08:36 PM
TeknoKing's Avatar
According to the manual, remove an address book, hit hfl, say setup and then clear, follow the instruction to completely remove everything.
In regards to the HOME Pin, it says your dealer can remove the pin.
Old Oct 25, 2011 | 08:13 AM
TecSavi's Avatar
NBP04TL4ME - I have the exact same car as you and wanted to delete the diagnostic info as well. On our NAV systems follow the steps below:
Hold "Map/Guide", "Menu" and "Cancel" for 5 seconds. This will get you to the diagnostic menu. Press the XM button on the bottom right and then press the bottom button to get a screen where delete diagnostic is an option. Once you press this you get a dialog box that says "Restarting Acuralink will require activation. Are you sure?"
Anyone one know if it is the NAV code or radio code that is required to activate Acuralink?
Old Oct 25, 2011 | 08:17 AM
TecSavi's Avatar
Sorry, replied to wrong post but do you know what they need for the Acuralink activation?
Old Oct 25, 2011 | 06:01 PM
NBP04TL4ME's Avatar
Not sure myself. I have tried two different cell phones with differing providers and I haven't been able to get it to work. Not sure if anyone has had success with this and I haven't bothered to ask the dealer.
Old Apr 13, 2015 | 12:17 PM
JetJaguar's Avatar
6th Gear
spaseeba
Nice. Thanks.
Old Sep 29, 2019 | 10:26 PM
Edgar Aguiar's Avatar
Got to the right screen on my navi but wont let me access diagnostic messages. My messages are popping up on my dash. Is it the same for you guys? 2011 RL
4drviper
Apr 23, 2025 07:13 PM
MilanoRedDashR
Oct 2, 2015 10:49 AM
hashbrown
Sep 29, 2015 12:13 PM
rockyboy
Sep 25, 2015 10:44 AM
