deck speakers
Old Oct 25, 2008 | 05:55 PM
ac-attack's Avatar
deck speakers
whats a good pair speakers for the back deck...im already running id components up front and i just want something cheap in the back to put out decent bass since the stock subwoofer doesnt do much im lookin to spend like 70-80
Old Oct 25, 2008 | 06:34 PM
eggyhustles's Avatar
deaden those front doors if you need more bass..
Old Oct 25, 2008 | 08:05 PM
Trew's Avatar
I doubt you're going to get 6 1/2's to give you decent bass unless you go with components. And those are not cheap.
Old Oct 26, 2008 | 10:39 AM
I hate cars's Avatar
Anything else you can do for more bass? My doors are fully deadened and sealed. I've run the Infinities, a friend's high end JL audio components, and now the ID CTX65 components. The IDs have the most bass so far but my cheap rental car that I'm driving has much more bass, so does the girlfriend's Murano with the base audio system. I've tried enough speakers to rule that out. I get a fair amount of excursion from the mids so I'm thinking cancellation.
I should mention the Infinities are now in the Murano and they have twice the bass they did in the TL.
Old Oct 26, 2008 | 01:44 PM
do you have the speakers mounted on a mdf ring? also what amp is powering them?
Old Oct 26, 2008 | 02:21 PM
Yep, MDF ring. I have a JL 6-channel amp with 75 watts rms. I've even tried running them with with the crossover at 50hz and no difference. Bass on the stock headunit is maxed out.
Old Oct 26, 2008 | 02:44 PM
you're underpowering those speakers..what do you have running in the rears? stocks?
Old Oct 26, 2008 | 05:32 PM
Stock in the rears because I usually have them off. So, assuming I have 200watts rms (bridged to 3 channels, I believe this amp puts out in the neighborhood of 200watts), I don't want to crank it to insane levels to get decent midbass.
I think it's more of an installation issue since the Infinities sound so much better in the Murano than the TL.
Old Oct 26, 2008 | 05:44 PM
Trew's Avatar
This may be a longshot but try checking the polarity on your speaker connections.
kb1rl
Sep 30, 2015 10:17 AM
Ratheruneeq
Sep 28, 2015 07:41 AM
polish_pat
Sep 25, 2015 12:24 PM
rboller
Sep 23, 2015 02:49 PM
