Confused about system upgrade? 5 channel issues...
Old May 24, 2010 | 09:21 AM
jrsmiles's Avatar
I've been researching the forum and reading a lot of the car audio threads posted in the FAQ thread. I'm still a little confused about how to upgrade my sound system while retaining the 5 channels already in place. I'd like to build an all JL Audio system and I'm not seeing a good option for a 5 channel amp with them. I plan on using one amp for the full range speakers and one for the sub. I've been looking at the JL XD600/6 6 channel amp, maybe that will do the trick. I'd just end up wasting a channel.
Another option might be 3 amps, a four channel and a 2 channel, along with the sub amp. I'd still end up wasting a channel.
How do I power the center channel as equally as the door components and deck speakers, what is the cleanest and easiest way?
Thanks for the input...
Old May 24, 2010 | 11:48 AM
spdosnd's Avatar
4th Gear
To power the center channel you should consider a DSP (Digital Signal Processor) that has an output for a center channel. A lot of guys using CARPC's wire for 5.1 audio.. Its not hard or expensive.. you can usually get better imaging than factory.
Old May 24, 2010 | 11:53 AM
jrsmiles's Avatar
I understand DSPs to be signal only, where would the power come from?
Old May 25, 2010 | 10:53 PM
xxx_busa's Avatar
5 channel is good for home theater, and 2 channel is good for audio, when your ready to commit to audio only, and what I mean by that is giving up on keeping the existing system the same. Then you'll find loads of assistance here & @ DIYMA.com, 2 channel front is the only way to go............
Old May 26, 2010 | 12:00 AM
jrsmiles's Avatar
Totally ready for it. The only reason I want the center is mainly for the HFL sound. If there is a way I can ditch it I will. I've never been a fan of the DVD-A and 5.1 music out there. I much prefer the correct stereo mix.
Any ideas how to maintain the center for HFL and mix the output from the stock HU to a 2 channel amp(s)?
Old May 26, 2010 | 10:26 AM
xxx_busa's Avatar
I have only Left & Right fronts only 2007 TL type S, all of my HFL work correctly, I ditched the factory amp.
Old May 26, 2010 | 05:48 PM
DiamondJoeQuimby's Avatar
Codename Duchess
yeah, this will work fine.
If you want to keep the 5.1 which does have some cool factor, especially if you replace the h/u w/ something that plays DVD-Video (i.e. Kenwood DNX9960) w/ 5.1 pre-outs. Going that route I (personally) would do the XD600/6 bridged to 3 channels on L/C/R then either a second XD600/6 on rears and 2 subs or an XD400/4 on rears and 1 sub.
Or you could do what I plan on doing...at some point...in the distant future...which is 2 HD900/5s and run 150x3 to L/C/R, 100x2 for rear L/R and 500x2 for 2 subs.
Old May 26, 2010 | 08:01 PM
jrsmiles's Avatar
I would love to get some details of your setup. I'm curious how a 5.1 channel output from the head unit can be downmixed to 2ch and keep all of the signal.
I don't know much about the stock Navi head.
Old May 26, 2010 | 08:13 PM
Joe Foe from Buffalo's Avatar
This may help you
https://acurazine.com/forums/3g-tl-audio-bluetooth-electronics-navigation-94/jl-audio-gen-3-tl-777494/
Old May 27, 2010 | 11:02 AM
xxx_busa's Avatar
Its not a 5.1 system, Its a 2 channel car stereo first and foremost, And not until you put a DVD-A with 5.1 mixing on it. then its 5.1,
Feb 25, 2020 09:57 AM
cycdaniel
Dec 17, 2019 10:58 AM
sockr1
Oct 1, 2015 01:31 AM
Sep 17, 2015 09:01 PM
Sep 14, 2015 10:09 PM
