Completely upgrading audio system
Old 10-15-2015, 03:14 PM
akbears15's Avatar
So I am relatively new to this forum and car audio as a whole but I want to have a nice system in my 2004 TL. I want to replace everything. Head unit, door speakers, tweeters, and the rear speakers and sub-woofer. I just need help deciding what brand I should go with for certain speakers because I do want to have a high end system. I am willing to spend ($1000+) for everything But not trying to spend thousand and thousands of dollars. If that makes sense. I have a reasonable budget.
Another question. When I went to buy a new head unit I was talking to Geek squad, yes judge me, and they were telling me that in order to replace the head unit, you have to get a certain code from the dealer in order to have use of the radio. I don't know if this is a common occurrence or if its just me so any help here would be helpful.
Also with the headunit I was going with a 7" JVC CD/DVD - Built-In Bluetooth - In-Dash A/V Receiver.
LINK:: JVC 6.2" CDDVD BuiltIn Bluetooth InDash AV Receiver Black KWV21BT - Best Buy
As far as mounting harness goes, is there a mounting kit for the 3rd generation TL? or will I have to find an alternative. Again, really new at this and just need some help.
Ultimately, I will be doing a lot of research and will use the forums to help me get the best speakers and everything for this build. Any help is great. Let me know what is good and what I should avoid. any response is appreciated!
Old 10-15-2015, 04:13 PM
pohljm's Avatar
You cannot really put together a high end system for $1K. Is there a reason why you want to replace the HU? its the only piece worth saving and integration is complicated both electronically and cosmetically
Old 10-15-2015, 04:29 PM
7th Gear
jayrob1's Avatar
Hu
Just curious about your build, i have an 2008, with the navigation the screen is shot and I'm considering changing the whole thing as well. I took the car to car tronics they said they won't touch it because it to compacted
Old 10-15-2015, 05:00 PM
polish_pat's Avatar
If you're going for the full replacement package, you might want to consider the Pioneer AVH-4100NEX with Android Auto and Apple CarPlay. Yes, it's double the price, but if you're gonna keep the TL for a few years, you'll that having your phone as a working component of your sound system is HUGE plus. I helped a friend install this in his G35 and boy was I jealous. If I didnt already have a Grom setup with all the cables nicely hidden, i'd probably just buy the HU and keep the rest of the system
Old 10-15-2015, 05:51 PM
TacoBello's Avatar
Received 4,416 Likes on 3,322 Posts
Tell us more, Patty.
Old 10-15-2015, 06:02 PM
polish_pat's Avatar
Stop your childish pollution of other members threads. I'm sure it's very pleasing for new members to post on a new forum and having some intruder posting provocative, unrelated content
Old 10-15-2015, 07:14 PM
TacoBello's Avatar
I just wanted more info.
pohljm (10-15-2015)
Old 10-15-2015, 07:32 PM
cu2wagon's Avatar
Received 7,772 Likes on 5,045 Posts
OP says he wants high end and is willing to spend $1000+ but not "thousands and thousands". So lets say $1k-$2k.
You're not going to get audiophile quality for that but you should be able to put together a decent system for that budget. That JVC head isn't really "high end" (although that is a rather arbitrary definition in reality) but I once installed a JVC head in my mommies car and was pleasantly surprised at the performance for the price point. You could certainly do worse.
The nice thing about building your own modular system is that you can go about it in stages and can replace components as you feel they should or could be improved.
Just throwing a swag: if you like that JVC head, add some Infinity kappa components, and say a Fosgate amp and youll be in the $1500-$1800 range all in.
IMO that could be a good baller on a budget system.
Check out crutchfield for the whosywhatsits of harnesses and mounting adapters and shop the web for good deals. EBay if you don't mind grey market or "fell off the back of the truck" parts.
Good luck!
Old 10-15-2015, 10:21 PM
pohljm's Avatar
You can get close to high end for 1K if you keep the OEM HU, do the work yourself and plan your purchases.
SpraykwoN
ILX
10-27-2015 02:34 AM
Nafizur Sarai
10-25-2015 08:16 AM
rexflexall
10-20-2015 09:36 AM
fsmith
3G RLX (2013+)
10-12-2015 11:16 PM
Mainplay
10-09-2015 04:19 PM
Quick Reply: Completely upgrading audio system
