Clock adjustment on Navi TL's
Old Dec 4, 2006 | 06:44 PM
Precision Crafted's Avatar
Greetings:
After having my TL jumped this morning the clock in the upper display is wrong. I checked the clock for the Navi and it is correct.
There is suppose to be some method to adjust the clock through the radio but my '04 TL does not have a "h" or "m" indication on or near the present buttons.
If any one can help me I'd appreciate it.
Old Dec 4, 2006 | 06:47 PM
csmeance's Avatar
the one on the top display is connected to the navi, so you might have redo the navi time again. Is on page 4 of the setup.
Old Dec 4, 2006 | 06:49 PM
OK, I will have to give that a try now.
Old Dec 4, 2006 | 06:59 PM
Nope.
No luck. The time in the upper display stayed the same.
Old Dec 4, 2006 | 07:11 PM
Thorin78's Avatar
Previous Owner
try going thru the navi setup or something
Map/Guide + Menu + Cancel button all at the same time and hold it until you see a different menu.
You may have to reload the disc or something. if all else fails, take it to the dealer.
Old Dec 4, 2006 | 07:35 PM
Will Y.'s Avatar
Registered but harmless
Originally Posted by Precision Crafted
Nope.
Leave it alone; let the Navi and car cycle through a shut-down. The clock should catch up to the Navi clock tomorrow if not tonight.
If not, prior posters' advice is good- screen 4 on set-up menu for the Nav system has the clock adjustment.
Old Dec 4, 2006 | 08:21 PM
johnny--2k's Avatar
My Daily Driver
^^ Yup. I noticed this when driving from WI to CO as well. The time on the navi/clock is a little bit behind. It will take a bit for it to catch up. Just give it till tomorrow at the latest, if it is still not matched, try disconnecting the battery or just take it to the dealership and let them deal with it.
Old Dec 12, 2006 | 02:44 PM
Thanks everyone for your advice.
As of yet the clock still does not match the one for the Navi. It is getting closer but no cigar.
Old Dec 12, 2006 | 05:42 PM
johnny--2k's Avatar
My Daily Driver
I would just go to the dealership at this point. It seems like it is having some issues synchronizing.
Old Dec 12, 2006 | 08:43 PM
Klutch's Avatar
A-SPEC TL
loll....i havent even noticed a clock on my navi
Old Dec 13, 2006 | 11:59 AM
Press the set up button, press the 4th button on your screen then press the clock adjust button at the top. You can adjust the hours/minutes and some others things. The time by the way is military time.
Mike734
Dec 10, 2021 01:25 PM
Jul 16, 2017 07:33 AM
lanechanger
Oct 13, 2015 10:56 AM
TL14
Sep 24, 2015 04:37 PM
