Cleansweep HELP!!!
Old Mar 5, 2006 | 05:20 PM
cliff's Avatar
Team NightHawk VP
Cleansweep HELP!!!
i have the unit hooked up
the unit turns on when acc switch is turned on
but no sound goes through, UNTIL i unplug the oem speaker harness on the CS and plug it back in. i have tried it with the signal sense on and off, i was thinking maybe its a bad unit, but im not sure.
i have yellow hooked up to constant power
red to ign
blue to remote
black to ground
what gives, anyone had this problem before?
Old Mar 5, 2006 | 07:10 PM
bklynpanman's Avatar
321 whp SAE
red to ign
blue to remote
black to ground
i have the cleansweep.. didn't have this problem.. try to move the acc to a different line.. i ran mine to the fuse box.. you live close.. maybe we can meet up and take a look..
Old Mar 6, 2006 | 09:59 PM
Scott P's Avatar
Mobile Elec. Guru
We had this problem with the first cleensweep we installed on the 3g TL at our shop. I imagine that if you go through to calibrate it it also has trouble fixing all the channels? Ultimately after sitting on the phone with JL we came to realize that contrary to what we had been told on the TL the cleensweep is quite particular as to where you catch signal at. Make sure you have all the right speaker wires, and that you catch signal in between the radio and the factory amp, not after the amp as that is supposedly what was causing the problem.
Old Mar 6, 2006 | 10:59 PM
cliff's Avatar
Team NightHawk VP
i guess thats where my problem is, i have it signaled after the amp.
when i put in the sub it didnt work before the amp, so i was assuming this was the same deal. guess not, thanks...ill try to fix it tom
Old Mar 8, 2006 | 08:15 AM
tfe691's Avatar
You mean you hooked it to the sub wire before the amp right? If so the cleansweep won't work well because it only accepts full range inputs.
Old Mar 10, 2006 | 12:05 AM
cliff's Avatar
Team NightHawk VP
everything works now, thanks!!
now i gotta rerun a zero gauge thru the car and get a distribution block for my sub
kstanton512
May 17, 2011 02:37 PM
msmith
76
Feb 2, 2011 04:37 PM
l7h8626
Jul 2, 2008 09:31 AM
SoundOff
Feb 4, 2006 10:56 PM
