Center Console Lights
Old Oct 16, 2013 | 04:03 PM
Gnargasim's Avatar
I am not entirely sure what to call these lights. Its the buttons that surround the nav screen. I have been noticing that mine are going up like crazy all of the sudden. I mean the Mode, Cancel, Audio, A/C (I think Im not in the car right now) and one other one are now out and it is driving me crazy because it looks like crud. Can we replace these or and I up a creek since it is a part of the nav unit? $1 leds sure beat buying a new unit.
Thanks guys.
Old Oct 16, 2013 | 04:07 PM
Sure, if you're able to solder and calculate voltage drops and make sure you're using the right ohm resistors or find direct replacement LEDs, you can just replace the LEDs.
Old Oct 16, 2013 | 04:52 PM
DuoDSG's Avatar
Make it so
Thumbs up
No disrespect, but the above post...half of your response was unnecessary. He's only asking about replacements, not upgrading or doing crazy electrical work. No reason for such an erratic response.
OP, regarding your question:
I have had this happen plenty of times. Those are just standard interior LED lights, and they are painfully simple to replace. Dirt cheap as well.
On this diagram (for a 2004 TL, like mine), it's parts 5, 6, 7, 8 and 11. When you are on any website looking at parts diagrams, this is the "Center Console- Navi" section, and from there you can compare prices and get the right part numbers.
Each of these bulbs are similar, but you want to make sure you get the ones that actually fit for the button LEDs you're trying to replace. The resistances and voltages do differ depending on the location of the LED light, so you can't just get a bunch of 8s (for example) and expect them to worry in any position, for example.
Getting behind the console is the only tricky part- if you want to do it right, you will have to remove the center console, CD deck, etc. Once you've got the navi unit in your hands, all you need is a flathead screwdriver, turn it a quarter turn and voila! It comes right out. Just take the new LED, and screw it in half a turn and you're done. There are great DIYs here on the forum (in the 3G garage) with instructions on how to access behind the navi unit.
This is the way way you replace any of these interior cabin backlight LEDs as well. I've done it for my overhead buttons ( sunroof, interior light setting), trunk and mirror switches (near your left kneecap), seat heater switches, and all of the LEDs surrounding my navi. Which is to say, if I can do it without screwing it up, anyone can.
Good luck!
Old Oct 17, 2013 | 09:02 PM
Gnargasim's Avatar
That was exactly what I was looking for thank you very much.
Old Oct 17, 2013 | 09:03 PM
Gnargasim's Avatar
Related to that what website do you use?
Old Oct 24, 2013 | 03:04 PM
Mafyoso's Avatar
Balling in the...
Good luck!
Hey Bro do you know a website or a good place to order these LEDs? My Type S Dash lights near the radio are going out little by little and its annoying at night cause IDK what the buttons are since its dark as shit inside.
Old Oct 24, 2013 | 03:19 PM
Was unaware that they were bulbs you could replace, I thought they were soldered onto a board like some of the other lights in the car! Sorry OP!
Old Oct 24, 2013 | 08:26 PM
DeathMetal's Avatar
Fearless DIY Guy
They are filament wound bulbs, the only LEDs in the entire center console are positioned behind the radio knobs.
Thank-you for taking the time to post this, very helpful.
I had to restrain myself from nestling in to an e-bashing, but that statement is absolutely incorrect.
Old Oct 24, 2013 | 08:28 PM
DeathMetal's Avatar
Fearless DIY Guy
FYI: A directly LED replacement is known as a 'Neo-Wedge' and contains the OE fit bayonet base.
Old Oct 24, 2013 | 09:49 PM
DuoDSG's Avatar
Make it so
Thumbs up
Thanks for the corrections- it's true, they're not an LED in the strict sense as they do have a filament. That was definitely my bad, as I am going off of the appearance of the bulb (I don't know all that much about electrical engineering and such).
Again, the voltages and resistances comment was from me going over the parts diagrams and descriptions. The bulbs all *look* identical, yes, but whenever I order replacement interior bulbs for the center console I make sure to get the one designated for that space instead of just going off of appearances. It would be just my luck that getting 20 of the same part number wouldn't be interchangeable like I imagine they would be.
But again, that's just me being paranoid
Again, thanks for the correction!
Old Oct 24, 2013 | 10:55 PM
DeathMetal's Avatar
Fearless DIY Guy
An LED is a diode, which permit electron flow in a single direction whereas a filament bulb is purely resistive and non-directional.
Old Mar 9, 2015 | 02:50 PM
Gnargasim's Avatar
This is an old thread but some good information if your having this problem. Hopefully this can help some people out.
I want to replace all of the lights at one time but I want to use neo wedge LEDS.
Does anyone know about these and what I need to look for?
https://www.superbrightleds.com/prod...gauge/220,221/
Would these work or not? Also if they do work do I need to buy read (Type-s) or do I buy white or clear and they will appear red?
Old Mar 10, 2015 | 08:01 PM
lalotamps's Avatar
lights bulbs
Where i can find this lights bulbs???
Good luck!
Old Mar 20, 2015 | 03:23 PM
DuoDSG's Avatar
Make it so
Just go to any Acura parts website and look these up by parts number. You should be able to pull up a parts diagram as you're looking through their parts catalog, and you just want to order the ones that correspond to the switches you're needing to replace.
Old Mar 1, 2016 | 01:30 PM
Pilmo's Avatar
This is a good post because I just picked up at 07 Type S with 127K miles on it and the center console/steering wheel lights are looking dull. The audio button and the driver side heated seats button doesnt even light up anymore!!!
If you guys already done this changes how was it the DIY? was it pretty simple once you got it going or any trouble after replacing it?? Thanks
Old Mar 2, 2016 | 11:07 PM
DeathMetal's Avatar
Fearless DIY Guy
Neo wedge is PnP
Old Mar 2, 2016 | 11:34 PM
Gnargasim's Avatar
Yeah it was pretty simple. Time consuming more than anything. Make sure all your leds light up before you put everything back together as they are pole sensitive. Also make sure all or tight, i have one that flickers and it drives me nuts but so much work for a little fix.
Old Mar 3, 2016 | 01:08 PM
WDPanda's Avatar
BTW, it's not just "Neo-Wedge"
Specifically "T5 Neo-Wedge"
It's a few cents each on ebay for colour of choice.
Old Mar 5, 2016 | 01:23 AM
acuratl2006owner's Avatar
9th Gear
Its real simple to install the T5 led lights I have an 06,tl just the part getting behind is a pain but I got a teal color led in mine and they look amazing I can show u a pic ? But be real gentle putting the LEDs in cuz they need to be turned a certain way and always make sure ur power is off I made a mistake and left them in to see if they were all working n touched the back of the leds light n popped up a fuse lucky it was only a fuse cuz I lost all my lights inside and out ! So be careful
Feb 25, 2020 09:57 AM
james357
Feb 13, 2016 02:37 PM
bymotion
Nov 18, 2015 11:28 AM
PortlandRL
Sep 14, 2015 12:01 PM
