Can we install subs like this?
so i have searched to find a diy that would show how to do the same type of install on our tl's.. i would like to be able to use my factory unit to control my sub vol. if this is possible does any one have a diy or illustration how to do so
https://acurazine.com/forums/3g-tl-audio-bluetooth-electronics-navigation-94/i-want-add-just-sub-616144/
is this it? i have to take out my stock sub and put a line out convertor in place?
Coolest A-zine Member
This has been covered MANY times
1. Pull down the top trunk liner when you're in the trunk
2. Look up under there and you'll see a big hole in the middle with the sub nearly sticking out; there will be a plug connecting to the sub
3. Unhook that plug and that's your (Post-amp) Subwoofer (-) and (+) wires
4. Wire that into a Line-Out Convertor (LOC), which will allow you to run speaker wire into it and use RCA's from the LOC into your amp
5. Wire up the amp to the speaker; Do the ground/power/remote
DONE
Another route....
Our factory system has what's called a balanced/differential signal. It helps noise cancellation but it's a bitch to work with in a car. You can bypass step 3 and 4 if you find an amp that will accept a balanced signal. Here's a few that do
Only some of these amps..not their entire line
JL Slash and HD
Soundstream
Hifonics
TRU
Audison
Zapco REF
Precision Power
DONE
Another route....
JL Slash and HD
Soundstream
Hifonics
TRU
Audison
Zapco REF
Precision Power
Dogmatic Dinosaur
You don't really need a balanced signal amp to run a sub. You will cross all of the noise out of the signal anyway. A basic LOC will not convert balanced to regular anyway.
akbears15
15
11-05-2015 07:06 AM
Pegon95
09-15-2015 01:54 PM
DiamondJoeQuimby
09-10-2015 11:40 AM
alan_rich
09-07-2015 11:08 PM
