Calling Dealer from Navigation system
LUV MY 2007 CBP TLS
Hi guys, don't know if it has been posted before, did a search couldn't find anything... Anyway, do any of you know how to change the phone # of the dealer the nav can call if you want it to?..There seems to be a preset number from the dealer the car was purchased from and I want to change it to the dealer I deal with now. Anyone know how to do this
thanks for your help
LUV MY 2007 CBP TLS
i don't know about the older ones but when you get a maintenance code you get a message on nave screen and it tells you what's wrong there is an option to call dealer for an appointment when you hit the button on the screen it call the dealer it is programed with. I want to change that number. it is no where to be found
Keep Right Except to Pass
Is this Acura dealership the closest to you? If so, I would tell the Nav to find the nearest Acura dealership. Then each time you need to go to that dealership just go to menu and select Recent places because it would be saved until its bumped out. Hope that helps ya out.
Registered but harmless
Received 1,147 Likes
LUV MY 2007 CBP TLS
thanks for your replies but i know all that already, the issue is that the navi has a dealer preset in there and when you get a diagnostic error the voice comes on and explains the error and there is a button to call the dealer, when you press that button the navi calls a dealer automatically but its not the dealer i want... i guess no one knows??
LUV MY 2007 CBP TLS
LUV MY 2007 CBP TLS
Ok i don't see an option to make it your permanent dealer Where is tha option can you explain please thanks
1) Find the desired dealer (Navi menu: Enter destination > places > find by category > Acura/Honda dealers) and enter it as a destination in the Navi.
2) Once a route to that dealer is calculated, cancel the route.
3) Push the Set-up button and go to screen 2 to enter the "personal address," which will allow you to select that dealer from the "prior destination" list.
4) The next time you get the Navi menu screen, you can select "personal address" to locate that dealer's info, call the listed number on the HFL or set a route there.
Same approach works to store any other personal addresses you may want.
More detailed instructions are in the Navi manual.
cycdaniel
12-17-2019 10:58 AM
DiamondJoeQuimby
09-10-2015 11:40 AM
Gianni Formica
09-07-2015 08:28 PM
