Burak's Audio Install .
Hello All,
After spending almost 2 weeks I finally finished my install. I have read almost all custom audio instal threads here and added a little bit of my knowledge and I am extremely happy with the result. I would like to tahnk everyone for their contributions to this great site.
Here is the components of my system,
Front Components : Image Dynamics CTX65 CS
Rear Coaxials : Polk MOMO MMC 650
Subwoofer : Alpine Type R 12"
Amp for the speakers Alpine PDX-4.100
Sub Amp :Alpine PDX-1.600
RF 360.2 Sound processor
Knuconcepts amp wiring kit and speaker wires
I started my project with building a custom enclosure for the subwoofer. This was a very time consuming project since I have never done anything like this before (except repairing motorcycle fairing, but this is littler different)
First I taped the corner of the trunk with painters tape(3 layers) then added a layer of resin then fiberglass mat. After 2 layers this is what I ended up with.
![](http://i305.photobucket.com/albums/nn217/gogunbaba/DSC03989.jpg?t=1229813485)
I put a couple of more layers of resin and mat to reach the thickness I wanted. Then I started to cut the rings for the subwoofer. I wanted to the countersunk look, so I cut 2 different size of rings;
since I lost th actual cardboard rings that came with the woofer, I had to be creative and used a pan (wife still does not know) to get the appropriate size of ring.
![](http://i305.photobucket.com/albums/nn217/gogunbaba/DSC03992.jpg?t=1229813615)
glued 2 rings together with liquid nail and let it dry overnight.
![](http://i305.photobucket.com/albums/nn217/gogunbaba/DSC03994.jpg?t=1229813875)
used dowels and hot glue gun to give the rings the aim I wanted
![](http://i305.photobucket.com/albums/nn217/gogunbaba/DSC03995.jpg?t=1229813945)
side view
![](http://i305.photobucket.com/albums/nn217/gogunbaba/DSC03996.jpg?t=1229814060)
used a fleece and 3m spray glue to attach the fiberglass to the rings, then cover the fleece with 4 layers of resin and fiberglass mat.
![](http://i305.photobucket.com/albums/nn217/gogunbaba/DSC03998.jpg?t=1229814224)
measured the inside space for the correct cubic ft.
![](http://i305.photobucket.com/albums/nn217/gogunbaba/DSC03999.jpg?t=1229814275)
here is the final product. after completing this and seeing how much of a work it is, now I know why UNCALD4 charges $380 for this
)) it was a lot of work but I had fun.
side view
![](http://i305.photobucket.com/albums/nn217/gogunbaba/DSC04172.jpg?t=1229814629)
front speakers
After reading what everone did for the front speaker wires, I decided to do it right and not to tap into the factory wires. Hopefully the pictures below will help others to get an idea of what I did. I used 12 guage speaker wires for the fronts and rears.
As you know the door on the ACURA TL has a big plastic connector and there is no room around it to run a speaker wire. Drilling into the plastic piece was not an option for me (i know some others did) as the wire i used was too thick to do it. Here is what I did
First, i disconnected the white plastic connector and cut a half circle for the speaker wire to fit in.
![](http://i305.photobucket.com/albums/nn217/gogunbaba/DSC04081.jpg?t=1229815141)
I used a rubber grommet for protection and a piece of mind.
plastic connector in its place
![](http://i305.photobucket.com/albums/nn217/gogunbaba/DSC04083.jpg?t=1229815394)
finished product, the speaker wire is inside the rubber piece . I made a little whole on the back side of it for the speaker cable to go inside the door .
![](http://i305.photobucket.com/albums/nn217/gogunbaba/DSC04086.jpg?t=1229815450)
I had to cut the doors a little bit to fit Image dynamics components, here is the pictures of the tools I used,
little wheel for the dremel tool to make bigger hole on the door
![](http://i305.photobucket.com/albums/nn217/gogunbaba/DSC04094.jpg?t=1229815700)
![](http://i305.photobucket.com/albums/nn217/gogunbaba/DSC04092.jpg?t=1229815765)
doors dynomatted and ready for installation
I used half inch MDF ring for the speakers for better fit
![](http://i305.photobucket.com/albums/nn217/gogunbaba/DSC04091.jpg?t=1229815850)
here is install for the tweeters, I hope the pics will explain it all.
![](http://i305.photobucket.com/albums/nn217/gogunbaba/DSC04107.jpg?t=1229815944)
![](http://i305.photobucket.com/albums/nn217/gogunbaba/DSC04108.jpg?t=1229815995)
![](http://i305.photobucket.com/albums/nn217/gogunbaba/DSC04109.jpg?t=1229816039)
final look
![](http://i305.photobucket.com/albums/nn217/gogunbaba/DSC04082.jpg?t=1229815303)
final look
![](http://i305.photobucket.com/albums/nn217/gogunbaba/DSC04106.jpg?t=1229816097)
rear speakers
I dynomatted the rear deck and installed the polk momos. First, i cut mdf rings but they were two thick, so the rear deck did not go in its place with them. I got rid of them and I used 3m tape so the metal does not touch metal and screw all the speakers in it s place. Making a whole for the speakers were not easy as there wasn't enough room for the drill to fit in. I purchased a piece (8 "long and can be bent, I am not what it is called) for the drill and attached the drill bit and made the necessary holes.
Here are the pics
do not use them it will not clear
![](http://i305.photobucket.com/albums/nn217/gogunbaba/DSC04097.jpg?t=1229816663)
I took the speaker rings off, I used 3 m tapes and hide the crossovers in the rear deck (these crossovers are not adjustable and have no functionality)
Here are the pics
![](http://i305.photobucket.com/albums/nn217/gogunbaba/DSC04102.jpg?t=1229816744)
200,000 mile club
Nice job man. How are those front components sounding? I heard they will hit pretty hard with a lot of punch for a 6.5 inch woffer and have great highs. Where did you buy them?
Amp rack and 3 sixty.2 install
I used the spare tire area for my amps, I am in the process of building a plexi glass cover for the amps and the 3sixty.2 for a better look.
I cut a half and inch MDF for my amp rack and covered with some type of fabric - foam mixture. I used a screw where you mont the spare tire to stable te amp rack. I am going to get rid of the long RCA s and get short ones and will install a small fan for better air circulation.
![](http://i305.photobucket.com/albums/nn217/gogunbaba/DSC04166b.jpg?t=1229817215)
they are very good but I still need tons of adjusting to do on this system. For now, my amp gain settings are at minimum and I only spend an hour to tune the system using 3sixty.2.
BoricuaTL
04-08-2016 01:08 PM
Pegon95
09-15-2015 01:54 PM
DiamondJoeQuimby
09-10-2015 11:40 AM
