BT45-HON3 and IOS 9
Old Oct 6, 2015 | 11:50 AM
Jackas's Avatar
BT45-HON3 and IOS 9
Lost Bluetooth connection and can't get it back on my TL 3G
Does anyone else have this problem?
USA SPEC BT45-HON3
Old Oct 6, 2015 | 11:57 AM
unpair it from your phone and redo the connection
Old Oct 6, 2015 | 02:15 PM
Jackas's Avatar
Unpaired, repaired, it will only stay on channel 001 - AUX
I kinda remember it was showing BLUETOOTH but I am not certain
I have navigation and the XM BUTTON
Old Oct 6, 2015 | 07:04 PM
Jackas's Avatar
Thanks for moving this post. I'm away from PC and using iPhone and navigating Acurazime on a phone is not as easy
RESOLVED ISSUE
Here is a follow-up to my problem. I disconnected the device physically from the harness, reset dip switches, started car up with it disconnected, turned off vehicle, reconnected after setting dip switches, started up vehicle again, and it's back to normal.
As a matter of note, I don't use the AUX connection and it is without attachment to any cable, which may be the cause of the problem if AUX is selected inadverdantly as I did, and once there on AUX, it just won't go back to Bluetooth because it may need to connect to something in order to complete the selection process.
I have no idea, but I won't select AUX again
Hope this helps anyone who may have a similar issue.
MyAcuraRL
Jan 26, 2017 10:06 PM
thegipper
Oct 12, 2015 03:55 PM
osvaldo516
Oct 6, 2015 10:14 PM
Atxrldriver
Oct 4, 2015 07:25 AM
Dpak
Oct 3, 2015 05:12 PM
