Bluetooth System (HFL) has crashed - HELP!
Old Feb 1, 2005 | 09:20 PM
04SSMTLCanada's Avatar
Yesterday, my bluetooth system crashed. The MID (when you select Handsfree Link) says IN USE with Signal Strength and Battery. Neither of the HFL buttons do anything. Car was shut down overnight and HFL is still frozen! Turned off the bluetooth on the phone and no difference. Since the HFL has seized the Audio, can't listen to any Audio system device (CD/Radio, etc). The voice activated navi and climate system flash a message on the display that system cannot be used as another system is using the audio. Does anyone know how to reset this system without going to a dealer? Is there a fuse I can pull out and put back in? I want to also avoid taking out the battery cable, but if that's the only way, then I'll have to do it.
Old Feb 2, 2005 | 03:19 AM
wolftag's Avatar
I've had this happen. Is the MID staying on even when the car is off for a few hours?
Pull fuse in location 10 in the fuse panel in the driver's footwell. There is a fuse pulling tool inside of the engine compartment fuse box (under hood, driver's side, just behind the air cleaner cover -- pop the top and look for the white plastic puller).
Old Feb 2, 2005 | 06:47 AM
Thanks. I'll try that today.
Old Feb 2, 2005 | 08:45 AM
ludachrisvt's Avatar
Wants an M3 in
yup happens alot ... usually when i leave the car off for a while it resets though :/ its been annoying to say the least
Old Feb 2, 2005 | 04:14 PM
I tried taking the fuse out and it didn't work. The fuse kills the display, and doesn't seem to get the HFL to re-boot. Any other suggestions?
Old Feb 2, 2005 | 05:12 PM
crazymjb's Avatar
disconnect and reconect the battery. I dont think there is a back up anywhere so that should kill everything. Pull and replace all fuses. Why dont they use breakers?
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
SUPRMN84
Oct 7, 2015 09:46 PM
95oRANGEcRUSH
Sep 25, 2015 12:50 PM
Eggs999bacon
Sep 24, 2015 10:08 AM
