Bluetooth stopped working and now I cant pair...Problem w Phone or Car?
Old Nov 15, 2005 | 08:43 PM
apamin's Avatar
5th Gear
I have the Sprint LG-325 and it just stopped working all of the sudden. I deleted the settings on the phone and on the car and tried it again. It pairs just fine then it asks me for a name to call the new connection, it then thinks for a second and goes back to the main menu. Please help...is it the phone or the car? Has any one had this happen?
Old Nov 15, 2005 | 09:48 PM
vp911's Avatar
There could be many causes for this. One solution is disconnecting the battery (or pulling the appropriate fuses) to reset the HFL system. Doing this MAY require you to enter your navi and radio codes. This should reset the HFL system.
Old Nov 17, 2005 | 10:43 AM
apamin's Avatar
5th Gear
Any one know which fuse this would be?
Old Dec 29, 2005 | 01:47 PM
jafo's Avatar
Team Anthracite Member
I have the same exact problem. I got a new phone (SE W600i) and deleted my old phone. I went to pair my W600i, and it kept failing when I named my phone. After repeated attempts, my phone no longer sees the HandsFree Link anymore. My phone can still see other bluetooth devices. I tried turning the car off and on, but that didn't help. I'm taking my car in next week for regular servicing so I guess I'll ask them to help.
Old Jan 1, 2006 | 01:14 PM
mobilezen's Avatar
The manual is a good place to start.
How long ago did you get your W600?
Old Jan 1, 2006 | 01:50 PM
Pankul's Avatar
Computer Techie Geek
Cool
this happened to me, when I had a phone paired, and I re-flashed its firmware. When I tried to pair it again, it would exibihit the same behavious you mention.
I was simply able to fix it by, using a voice command to reset the System.
I dont remember exactly, but try this.
1 press the HFL button on the steering wheel.
then say 'help'. the command has something to do with system reset. You will loose all your pairing but will restore your system.
Old Jan 1, 2006 | 02:40 PM
mikef723's Avatar
Same thing happened to me a few times with my blackberry 7290. I think its a car issue and not a phone issue. I tried again a few days later and got it paired. Its been going good ever since, knock on wood.
Old Jan 1, 2006 | 08:34 PM
MINTCENT's Avatar
Swing by acura, ask them to use a TL for 5 min to try and pair your phone with another tl. You will know if its your TL or your Cell.
I had the same issue, my V600 would pair, but I had to manually do it everytime. It wouldnt just detect the phone in the car. I went to acura, after pairing my V600 with another TL and realizing that it worked perfectly with another TL I went back to try it in my car again, and I have no idea but it wokred perfectly in my ever since then.
kuzdu
Sep 10, 2015 08:42 PM
jordanboi
Sep 5, 2015 01:33 AM
dlknight
Sep 3, 2015 07:54 PM
tealt
Sep 1, 2015 09:03 AM
